x86/PCI: Convert release_resource to release_region/release_mem_region
Request_region should be used with release_region, not release_resource.
The local variables region and region2 are dropped and the calls to
release_resource are replaced with calls to release_region, using the first
two arguments of the corresponding calls to request_region.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x,E;
*x = request_region(...)
*x = request_mem_region(...)
... when != release_region(x)
    when != x = E
* release_resource(x);
Signed-off-by: Julia Lawall
Signed-off-by: Jesse Barnes
 arch/x86/pci/direct.c | 17 ++++++-----------
 1 file changed, 6 insertions(+), 11 deletions(-)
diff --git a/arch/x86/pci/direct.c b/arch/x86/pci/direct.c
index bd33620..e6fd847 100644
--- a/arch/x86/pci/direct.c
+++ b/arch/x86/pci/direct.c
@@ -280,12 +280,9 @@ void __init pci_direct_init(int type)
 int __init pci_direct_probe(void)
-	struct resource *region, *region2;
 	if ((pci_probe & PCI_PROBE_CONF1) == 0)
 		goto type2;
-	region = request_region(0xCF8, 8, "PCI conf1");
-	if (!region)
+	if (!request_region(0xCF8, 8, "PCI conf1"))
 		goto type2;
 	if (pci_check_type1()) {
@@ -293,16 +290,14 @@ int __init pci_direct_probe(void)
 		port_cf9_safe = true;
 		return 1;
-	release_resource(region);
+	release_region(0xCF8, 8);
  type2:
 	if ((pci_probe & PCI_PROBE_CONF2) == 0)
 		return 0;
-	region = request_region(0xCF8, 4, "PCI conf2");
-	if (!region)
+	if (!request_region(0xCF8, 4, "PCI conf2"))
 		return 0;
-	region2 = request_region(0xC000, 0x1000, "PCI conf2");
-	if (!region2)
+	if (!request_region(0xC000, 0x1000, "PCI conf2"))
 		goto fail2;
 	if (pci_check_type2()) {
@@ -311,8 +306,8 @@ int __init pci_direct_probe(void)
 		return 2;
-	release_resource(region2);
+	release_region(0xC000, 0x1000);
  fail2:
+	release_region(0xCF8, 4);
 	return 0;
BtrLinux
Privacy Overview
