hwrng: omap – Convert release_resource to release_region/release_mem_region
Request_region should be used with release_region, not release_resource.
The local variable mem, storing the result of request_mem_region, is
dropped and instead the pointer res is stored in the drvdata field of the
platform device.  This information is retrieved in omap_rng_remove to
release the region.  The drvdata field is not used elsewhere.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x,E;
*x = request_region(...)
*x = request_mem_region(...)
... when != release_region(x)
    when != x = E
* release_resource(x);
Signed-off-by: Julia Lawall
Signed-off-by: Herbert Xu
 drivers/char/hw_random/omap-rng.c | 14 ++++++--------
 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/drivers/char/hw_random/omap-rng.c b/drivers/char/hw_random/omap-rng.c
index 06aad08..2cc755a 100644
--- a/drivers/char/hw_random/omap-rng.c
+++ b/drivers/char/hw_random/omap-rng.c
@@ -91,7 +91,7 @@ static struct hwrng omap_rng_ops = {
 static int __devinit omap_rng_probe(struct platform_device *pdev)
-	struct resource *res, *mem;
+	struct resource *res;
 	int ret;
@@ -116,14 +116,12 @@ static int __devinit omap_rng_probe(struct platform_device *pdev)
 	if (!res)
 		return -ENOENT;
-	mem = request_mem_region(res->start, resource_size(res),
-				 pdev->name);
-	if (mem == NULL) {
+	if (!request_mem_region(res->start, resource_size(res), pdev->name)) {
 		ret = -EBUSY;
 		goto err_region;
-	dev_set_drvdata(&pdev->dev, mem);
+	dev_set_drvdata(&pdev->dev, res);
 	rng_base = ioremap(res->start, resource_size(res));
 	if (!rng_base) {
 		ret = -ENOMEM;
@@ -146,7 +144,7 @@ err_register:
 	iounmap(rng_base);
 	rng_base = NULL;
 err_ioremap:
-	release_resource(mem);
+	release_mem_region(res->start, resource_size(res));
 err_region:
 	if (cpu_is_omap24xx()) {
 		clk_disable(rng_ick);
@@ -157,7 +155,7 @@ err_region:
 static int __exit omap_rng_remove(struct platform_device *pdev)
-	struct resource *mem = dev_get_drvdata(&pdev->dev);
+	struct resource *res = dev_get_drvdata(&pdev->dev);
 	hwrng_unregister(&omap_rng_ops);
@@ -170,7 +168,7 @@ static int __exit omap_rng_remove(struct platform_device *pdev)
 		clk_put(rng_ick);
 	rng_base = NULL;
 	return 0;
