drivers/char/pcmcia/ipwireless/main.c | 52 +++++++++++++++++++++--------------
1 file changed, 32 insertions(+), 20 deletions(-)
diff --git a/drivers/char/pcmcia/ipwireless/main.c b/drivers/char/pcmcia/ipwireless/main.c
index 94b8eb4..444155a 100644
--- a/drivers/char/pcmcia/ipwireless/main.c
+++ b/drivers/char/pcmcia/ipwireless/main.c
@@ -78,7 +78,6 @@ static void signalled_reboot_callback(void *callback_data)
static int ipwireless_probe(struct pcmcia_device *p_dev, void *priv_data)
struct ipw_dev *ipw = priv_data;
- struct resource *io_resource;
int ret;
p_dev->resource[0]->flags &= ~IO_DATA_PATH_WIDTH;
@@ -92,9 +91,12 @@ static int ipwireless_probe(struct pcmcia_device *p_dev, void *priv_data)
if (ret)
return ret;
- io_resource = request_region(p_dev->resource[0]->start,
- resource_size(p_dev->resource[0]),
- IPWIRELESS_PCCARD_NAME);
+ if (!request_region(p_dev->resource[0]->start,
+ resource_size(p_dev->resource[0]),
+ IPWIRELESS_PCCARD_NAME)) {
+ ret = -EBUSY;
+ goto exit;
p_dev->resource[2]->flags |=
WIN_DATA_WIDTH_16 | WIN_MEMORY_TYPE_CM | WIN_ENABLE;
@@ -105,22 +107,25 @@ static int ipwireless_probe(struct pcmcia_device *p_dev, void *priv_data)
ret = pcmcia_map_mem_page(p_dev, p_dev->resource[2], p_dev->card_addr);
if (ret != 0)
- goto exit2;
+ goto exit1;
ipw->is_v2_card = resource_size(p_dev->resource[2]) == 0x100;
- ipw->attr_memory = ioremap(p_dev->resource[2]->start,
+ ipw->common_memory = ioremap(p_dev->resource[2]->start,
resource_size(p_dev->resource[2]));
- request_mem_region(p_dev->resource[2]->start,
- resource_size(p_dev->resource[2]),
+ if (!request_mem_region(p_dev->resource[2]->start,
+ resource_size(p_dev->resource[2]),
+ ret = -EBUSY;
+ goto exit2;
p_dev->resource[3]->flags |= WIN_DATA_WIDTH_16 | WIN_MEMORY_TYPE_AM |
WIN_ENABLE;
p_dev->resource[3]->end = 0; /* this used to be 0x1000 */
ret = pcmcia_request_window(p_dev, p_dev->resource[3], 0);
if (ret != 0)
- goto exit2;
+ goto exit3;
ret = pcmcia_map_mem_page(p_dev, p_dev->resource[3], 0);
if (ret != 0)
@@ -128,23 +133,28 @@ static int ipwireless_probe(struct pcmcia_device *p_dev, void *priv_data)
ipw->attr_memory = ioremap(p_dev->resource[3]->start,
resource_size(p_dev->resource[3]));
- request_mem_region(p_dev->resource[3]->start,
- resource_size(p_dev->resource[3]),
+ if (!request_mem_region(p_dev->resource[3]->start,
+ resource_size(p_dev->resource[3]),
+ ret = -EBUSY;
+ goto exit4;
return 0;
+exit4:
+ iounmap(ipw->attr_memory);
exit3:
+ release_mem_region(p_dev->resource[2]->start,
+ resource_size(p_dev->resource[2]));
exit2:
- if (ipw->common_memory) {
- release_mem_region(p_dev->resource[2]->start,
- resource_size(p_dev->resource[2]));
- iounmap(ipw->common_memory);
+ iounmap(ipw->common_memory);
exit1:
- release_resource(io_resource);
+ release_region(p_dev->resource[0]->start,
+ resource_size(p_dev->resource[0]));
+exit:
pcmcia_disable_device(p_dev);
- return -1;
+ return ret;
static int config_ipwireless(struct ipw_dev *ipw)
@@ -219,6 +229,8 @@ exit:
static void release_ipwireless(struct ipw_dev *ipw)
+ release_region(ipw->link->resource[0]->start,
+ resource_size(ipw->link->resource[0]));
release_mem_region(ipw->link->resource[2]->start,
resource_size(ipw->link->resource[2])); |
