watchdog: imx2_wdt.c: use devm_request_and_ioremap
Reimplement a call to devm_request_mem_region followed by a call to ioremap
or ioremap_nocache by a call to devm_request_and_ioremap.
The variable res_size is then no longer needed.
The semantic patch that makes this transformation is as follows:
(http://coccinelle.lip6.fr/)
@nm@
expression myname;
identifier i;
struct platform_driver i = { .driver = { .name = myname } };
expression dev,res,size;
expression nm.myname;
-if (!devm_request_mem_region(dev, res->start, size,
-                              \(res->name\|dev_name(dev)\|myname\))) {
-   return ...;
... when != res->start
-devm_ioremap(dev,res->start,size)
+devm_request_and_ioremap(dev,res)
-devm_ioremap_nocache(dev,res->start,size)
... when any
    when != res->start
Signed-off-by: Julia Lawall
Signed-off-by: Wim Van Sebroeck
 drivers/watchdog/imx2_wdt.c | 11 +----------
 1 file changed, 1 insertion(+), 10 deletions(-)
diff --git a/drivers/watchdog/imx2_wdt.c b/drivers/watchdog/imx2_wdt.c
index b8ef2c6..c44c333 100644
--- a/drivers/watchdog/imx2_wdt.c
+++ b/drivers/watchdog/imx2_wdt.c
@@ -247,7 +247,6 @@ static struct miscdevice imx2_wdt_miscdev = {
 static int __init imx2_wdt_probe(struct platform_device *pdev)
 	int ret;
-	int res_size;
 	struct resource *res;
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
@@ -256,15 +255,7 @@ static int __init imx2_wdt_probe(struct platform_device *pdev)
 		return -ENODEV;
-	res_size = resource_size(res);
-	if (!devm_request_mem_region(&pdev->dev, res->start, res_size,
-		res->name)) {
-		dev_err(&pdev->dev, "can't allocate %d bytes at %d address\n",
-			res_size, res->start);
-		return -ENOMEM;
-	imx2_wdt.base = devm_ioremap_nocache(&pdev->dev, res->start, res_size);
+	imx2_wdt.base = devm_request_and_ioremap(&pdev->dev, res);
 	if (!imx2_wdt.base) {
 		dev_err(&pdev->dev, "ioremap failed\n");
 		return -ENOMEM;
BtrLinux
Privacy Overview
