drivers/gpio/gpio-tegra.c: use devm_request_and_ioremap
Reimplement a call to devm_request_mem_region followed by a call to ioremap
or ioremap_nocache by a call to devm_request_and_ioremap.
The semantic patch that makes this transformation is as follows:
(http://coccinelle.lip6.fr/)
@nm@
expression myname;
identifier i;
struct platform_driver i = { .driver = { .name = myname } };
expression dev,res,size;
expression nm.myname;
-if (!devm_request_mem_region(dev, res->start, size,
-                              \(res->name\|dev_name(dev)\|myname\))) {
-   return ...;
... when != res->start
-devm_ioremap(dev,res->start,size)
+devm_request_and_ioremap(dev,res)
-devm_ioremap_nocache(dev,res->start,size)
... when any
    when != res->start
Signed-off-by: Julia Lawall
Signed-off-by: Grant Likely
 drivers/gpio/gpio-tegra.c | 9 +--------
 1 file changed, 1 insertion(+), 8 deletions(-)
diff --git a/drivers/gpio/gpio-tegra.c b/drivers/gpio/gpio-tegra.c
index 61044c8..bdc2937 100644
--- a/drivers/gpio/gpio-tegra.c
+++ b/drivers/gpio/gpio-tegra.c
@@ -361,14 +361,7 @@ static int __devinit tegra_gpio_probe(struct platform_device *pdev)
 		return -ENODEV;
-	if (!devm_request_mem_region(&pdev->dev, res->start,
-				     resource_size(res),
-				     dev_name(&pdev->dev))) {
-		dev_err(&pdev->dev, "Couldn't request MEM resource\n");
-		return -ENODEV;
-	regs = devm_ioremap(&pdev->dev, res->start, resource_size(res));
+	regs = devm_request_and_ioremap(&pdev->dev, res);
 	if (!regs) {
 		dev_err(&pdev->dev, "Couldn't ioremap regs\n");
 		return -ENODEV;
