mtd: lantiq-flash: drop iounmap for devm_ allocated data
Data allocated with devm_ioremap or devm_ioremap_nocache should not be
freed using iounmap, because doing so causes a dangling pointer, and a
subsequent double free.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
expression x;
x = devm_ioremap(...)
x = devm_ioremap_nocache(...)
expression r.x;
* iounmap(x)
Signed-off-by: Julia Lawall
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
drivers/mtd/maps/lantiq-flash.c | 6 +-----
1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/mtd/maps/lantiq-flash.c b/drivers/mtd/maps/lantiq-flash.c
index 4f10e27..7b889de 100644
--- a/drivers/mtd/maps/lantiq-flash.c
+++ b/drivers/mtd/maps/lantiq-flash.c
@@ -159,7 +159,7 @@ ltq_mtd_probe(struct platform_device *pdev)
if (!ltq_mtd->mtd) {
dev_err(&pdev->dev, "probing failed\n");
err = -ENXIO;
- goto err_unmap;
+ goto err_free;
ltq_mtd->mtd->owner = THIS_MODULE;
@@ -179,8 +179,6 @@ ltq_mtd_probe(struct platform_device *pdev)
err_destroy:
map_destroy(ltq_mtd->mtd);
-err_unmap:
- iounmap(ltq_mtd->map->virt);
err_free:
kfree(ltq_mtd->map);
err_out:
@@ -198,8 +196,6 @@ ltq_mtd_remove(struct platform_device *pdev)
mtd_device_unregister(ltq_mtd->mtd);
- if (ltq_mtd->map->virt)
kfree(ltq_mtd);
err = -ENXIO;
- goto err_unmap;
+ goto err_free;
err_destroy:
-err_unmap:
err_free:
err_out:
kfree(ltq_mtd);
