watchdog: dw_wdt.c: use devm_request_and_ioremap
Reimplement a call to devm_request_mem_region followed by a call to ioremap
or ioremap_nocache by a call to devm_request_and_ioremap.
The semantic patch that makes this transformation is as follows:
(http://coccinelle.lip6.fr/)
@nm@
expression myname;
identifier i;
struct platform_driver i = { .driver = { .name = myname } };
expression dev,res,size;
expression nm.myname;
-if (!devm_request_mem_region(dev, res->start, size,
- \(res->name\|dev_name(dev)\|myname\))) {
- return ...;
... when != res->start
-devm_ioremap(dev,res->start,size)
+devm_request_and_ioremap(dev,res)
-devm_ioremap_nocache(dev,res->start,size)
... when any
when != res->start
Signed-off-by: Julia Lawall
Signed-off-by: Wim Van Sebroeck
drivers/watchdog/dw_wdt.c | 6 +-----
1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/drivers/watchdog/dw_wdt.c b/drivers/watchdog/dw_wdt.c
index 1b0e3dd..63d7b58 100644
--- a/drivers/watchdog/dw_wdt.c
+++ b/drivers/watchdog/dw_wdt.c
@@ -300,11 +300,7 @@ static int __devinit dw_wdt_drv_probe(struct platform_device *pdev)
if (!mem)
return -EINVAL;
- if (!devm_request_mem_region(&pdev->dev, mem->start, resource_size(mem),
- "dw_wdt"))
- return -ENOMEM;
- dw_wdt.regs = devm_ioremap(&pdev->dev, mem->start, resource_size(mem));
+ dw_wdt.regs = devm_request_and_ioremap(&pdev->dev, mem);
if (!dw_wdt.regs)
return -ENOMEM; |
if (!mem)
return -EINVAL;
- "dw_wdt"))
- return -ENOMEM;
if (!dw_wdt.regs)
return -ENOMEM;
