tty: tty_ldsem.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Jiri Slaby
drivers/tty/tty_ldsem.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/tty/tty_ldsem.c b/drivers/tty/tty_ldsem.c
index 0ffb0cb..ad7eba5 100644
--- a/drivers/tty/tty_ldsem.c
+++ b/drivers/tty/tty_ldsem.c
@@ -299,7 +299,8 @@ down_write_failed(struct ld_semaphore *sem, long count, long timeout)
timeout = schedule_timeout(timeout);
raw_spin_lock_irq(&sem->wait_lock);
set_task_state(tsk, TASK_UNINTERRUPTIBLE);
- if ((locked = writer_trylock(sem)))
+ locked = writer_trylock(sem);
+ if (locked)
break;
+ if (locked)
break;
