tty: tty_buffer.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Jiri Slaby
drivers/tty/tty_buffer.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/tty/tty_buffer.c b/drivers/tty/tty_buffer.c
index 7566164..5b2b0ff 100644
--- a/drivers/tty/tty_buffer.c
+++ b/drivers/tty/tty_buffer.c
@@ -262,7 +262,8 @@ static int __tty_buffer_request_room(struct tty_port *port, size_t size,
change = (b->flags & TTYB_NORMAL) && (~flags & TTYB_NORMAL);
if (change || left < size) {
/* This is the slow path - looking for new buffers to use */
- if ((n = tty_buffer_alloc(port, size)) != NULL) {
+ n = tty_buffer_alloc(port, size);
+ if (n != NULL) {
n->flags = flags;
buf->tail = n;
b->commit = b->used; |
+ if (n != NULL) {
n->flags = flags;
buf->tail = n;
