USB: ehci-dbg.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
Acked-by: Alan Stern
Reviewed-by: Felipe Balbi
drivers/usb/host/ehci-dbg.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-dbg.c b/drivers/usb/host/ehci-dbg.c
index 524cbf2..b26b96e 100644
--- a/drivers/usb/host/ehci-dbg.c
+++ b/drivers/usb/host/ehci-dbg.c
@@ -628,7 +628,8 @@ static ssize_t fill_periodic_buffer(struct debug_buffer *buf)
unsigned i;
__hc32 tag;
- if (!(seen = kmalloc (DBG_SCHED_LIMIT * sizeof *seen, GFP_ATOMIC)))
+ seen = kmalloc(DBG_SCHED_LIMIT * sizeof *seen, GFP_ATOMIC);
+ if (!seen)
return 0;
seen_count = 0; |
unsigned i;
__hc32 tag;
+ if (!seen)
return 0;
seen_count = 0;
