staging:vt6655: Fix sparse warnings of using plain integer as NULL pointer
Author: Himangi Saraogi <himangi774@gmail.com>
This patch fixes the following sparse warnings:
drivers/staging/vt6655/wmgr.c:970:42: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:971:41: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:972:38: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:973:43: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:4110:37: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:4111:41: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:4112:34: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:4113:30: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:4114:35: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:4123:32: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:1815:41: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:1816:34: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:1817:30: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:1818:35: warning: Using plain integer as NULL pointer
drivers/staging/vt6655/wmgr.c:2075:63: warning: Using plain integer as NULL pointer
The following coccinelle script was used to achieve this:
@rule1@
expression *x;
- x = 0;
+ x = NULL;
- (x == 0)
+ (x == NULL)
- (x != 0)
+ (x != NULL)
Signed-off-by: Himangi Saraogi
Acked-by: Paul E. McKenney
drivers/staging/vt6655/wmgr.c | 30 +++++++++++++++---------------
1 file changed, 15 insertions(+), 15 deletions(-)
diff --git a/drivers/staging/vt6655/wmgr.c b/drivers/staging/vt6655/wmgr.c
index 5200a2a..b673bc9 100644
--- a/drivers/staging/vt6655/wmgr.c
+++ b/drivers/staging/vt6655/wmgr.c
@@ -967,10 +967,10 @@ s_vMgrRxAssocResponse(
sFrame.pBuf = (unsigned char *)pRxPacket->p80211Header;
// decode the frame
vMgrDecodeAssocResponse(&sFrame);
- if ((sFrame.pwCapInfo == 0) ||
- (sFrame.pwStatus == 0) ||
- (sFrame.pwAid == 0) ||
- (sFrame.pSuppRates == 0)) {
+ if ((sFrame.pwCapInfo == NULL) ||
+ (sFrame.pwStatus == NULL) ||
+ (sFrame.pwAid == NULL) ||
+ (sFrame.pSuppRates == NULL)) {
DBG_PORT80(0xCC);
return;
@@ -1812,10 +1812,10 @@ s_vMgrRxBeacon(
// decode the beacon frame
vMgrDecodeBeacon(&sFrame);
- if ((sFrame.pwBeaconInterval == 0) ||
- (sFrame.pwCapInfo == 0) ||
- (sFrame.pSSID == 0) ||
+ if ((sFrame.pwBeaconInterval == NULL) ||
+ (sFrame.pwCapInfo == NULL) ||
+ (sFrame.pSSID == NULL) ||
DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Rx beacon frame error\n");
return;
@@ -2072,7 +2072,7 @@ s_vMgrRxBeacon(
if (bTSFLargeDiff)
bUpdateTSF = true;
- if (pDevice->bEnablePSMode && (sFrame.pTIM != 0)) {
+ if (pDevice->bEnablePSMode && (sFrame.pTIM != NULL)) {
// deal with DTIM, analysis TIM
pMgmt->bMulticastTIM = WLAN_MGMT_IS_MULTICAST_TIM(sFrame.pTIM->byBitMapCtl) ? true : false;
pMgmt->byDTIMCount = sFrame.pTIM->byDTIMCount;
@@ -4107,11 +4107,11 @@ s_vMgrRxProbeResponse(
vMgrDecodeProbeResponse(&sFrame);
- if ((sFrame.pqwTimestamp == 0) ||
- (sFrame.pwBeaconInterval == 0) ||
+ if ((sFrame.pqwTimestamp == NULL) ||
+ (sFrame.pwBeaconInterval == NULL) ||
DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Probe resp:Fail addr:[%p] \n", pRxPacket->p80211Header);
DBG_PORT80(0xCC);
return;
@@ -4120,7 +4120,7 @@ s_vMgrRxProbeResponse(
if (sFrame.pSSID->len == 0)
DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Rx Probe resp: SSID len = 0 \n");
- if (sFrame.pDSParms != 0) {
+ if (sFrame.pDSParms != NULL) {
if (byCurrChannel > CB_MAX_CHANNEL_24G) {
// channel remapping to
byIEChannel = get_channel_mapping(pMgmt->pAdapter, sFrame.pDSParms->byCurrChannel, PHY_TYPE_11A); |
// decode the frame
DBG_PORT80(0xCC);
return;
return;
if (bTSFLargeDiff)
bUpdateTSF = true;
DBG_PORT80(0xCC);
return;
