Staging: solo6x10: Replace expressions that don’t use ALIGN macro
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
There are some expressions that compute the roundup of a number, but don't use
the existing macro defined in /include/kernel.h. This patch uses the following
Coccinelle semantic patch:
@ haskernel @
@ depends on haskernel @
expression E1, E2;
- (E1 + (E2 - 1)) & ~(E2 - 1)
+ ALIGN(E1, E2)
Signed-off-by: Andreea-Cristina Bernat
Acked-by: Bob Copeland
Signed-off-by: Peter P Waskiewicz Jr
 drivers/staging/media/solo6x10/solo6x10-v4l2-enc.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/media/solo6x10/solo6x10-v4l2-enc.c b/drivers/staging/media/solo6x10/solo6x10-v4l2-enc.c
index 6dc32f6..5aeb9c0 100644
--- a/drivers/staging/media/solo6x10/solo6x10-v4l2-enc.c
+++ b/drivers/staging/media/solo6x10/solo6x10-v4l2-enc.c
@@ -472,8 +472,7 @@ static int solo_fill_jpeg(struct solo_enc_dev *solo_enc,
 	if (vb2_plane_size(vb, 0) < vop_jpeg_size(vh) + solo_enc->jpeg_len)
 		return -EIO;
-	frame_size = (vop_jpeg_size(vh) + solo_enc->jpeg_len + (DMA_ALIGN - 1))
-		& ~(DMA_ALIGN - 1);
+	frame_size = ALIGN(vop_jpeg_size(vh) + solo_enc->jpeg_len, DMA_ALIGN);
 	vb2_set_plane_payload(vb, 0, vop_jpeg_size(vh) + solo_enc->jpeg_len);
 	/* may discard all previous data in vbuf->sgl */
@@ -521,8 +520,7 @@ static int solo_fill_mpeg(struct solo_enc_dev *solo_enc,
 	/* Now get the actual mpeg payload */
 	frame_off = (vop_mpeg_offset(vh) - SOLO_MP4E_EXT_ADDR(solo_dev) +
 		sizeof(*vh)) % SOLO_MP4E_EXT_SIZE(solo_dev);
-	frame_size = (vop_mpeg_size(vh) + skip + (DMA_ALIGN - 1))
+	frame_size = ALIGN(vop_mpeg_size(vh) + skip, DMA_ALIGN);
 	dma_map_sg(&solo_dev->pdev->dev, vbuf->sgl, vbuf->nents,
