staging: slicoss: free IO remapping on failure
Author: Kristina Martšenko <kristina.martsenko@gmail.com>
Make sure iounmap is always called after ioremap when module loading
fails. Also remove a call to release_mem_region because that region is
never reserved in the first place.
Fixes the following issue reported by Coccinelle:
drivers/staging/slicoss/slicoss.c:3727:1-7: ERROR: missing iounmap; ioremap on line 3661 and execution via conditional on line 3677
Signed-off-by: Kristina Martšenko
drivers/staging/slicoss/slicoss.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/slicoss/slicoss.c b/drivers/staging/slicoss/slicoss.c
index 55e4d82..e27b88f 100644
--- a/drivers/staging/slicoss/slicoss.c
+++ b/drivers/staging/slicoss/slicoss.c
@@ -3676,7 +3676,7 @@ static int slic_entry_probe(struct pci_dev *pcidev,
err = slic_card_locate(adapter);
if (err) {
dev_err(&pcidev->dev, "cannot locate card\n");
- goto err_out_free_mmio_region;
+ goto err_out_unmap;
card = adapter->card;
@@ -3716,8 +3716,6 @@ static int slic_entry_probe(struct pci_dev *pcidev,
err_out_unmap:
iounmap(memmapped_ioaddr);
-err_out_free_mmio_region:
- release_mem_region(mmio_start, mmio_len);
err_out_free_netdev:
free_netdev(netdev);
err_out_exit_slic_probe: |
if (err) {
err_out_unmap:
