Staging: wilc1000: Remove typedefs for struct
Author: Shraddha Barke <shraddha.6596@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs for
structure and enum types. This patch gets rid of the typedefs for
Ack_session_info_t.
The following Coccinelle semantic patch detects the cases for struct type:
@tn@
identifier i;
type td;
-typedef
 struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Shraddha Barke
 drivers/staging/wilc1000/wilc_wlan.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/wilc1000/wilc_wlan.c b/drivers/staging/wilc1000/wilc_wlan.c
index def72fd..1eb13f9 100644
--- a/drivers/staging/wilc1000/wilc_wlan.c
+++ b/drivers/staging/wilc1000/wilc_wlan.c
@@ -291,13 +291,13 @@ uint32_t Statisitcs_totalAcks = 0, Statisitcs_DroppedAcks = 0;
 #ifdef	TCP_ACK_FILTER
 struct Ack_session_info;
-typedef struct Ack_session_info {
+struct Ack_session_info {
 	uint32_t Ack_seq_num;
 	uint32_t Bigger_Ack_num;
 	uint16_t src_port;
 	uint16_t dst_port;
 	uint16_t status;
-} Ack_session_info_t;
 typedef struct {
 	uint32_t ack_num;
@@ -318,7 +318,7 @@ struct Ack_session_info *Alloc_head;
 #define MAX_TCP_SESSION		25
 #define MAX_PENDING_ACKS		256
-Ack_session_info_t Acks_keep_track_info[2 * MAX_TCP_SESSION];
+struct Ack_session_info Acks_keep_track_info[2 * MAX_TCP_SESSION];
 Pending_Acks_info_t Pending_Acks_info[MAX_PENDING_ACKS];
 uint32_t PendingAcks_arrBase;
BtrLinux
Privacy Overview
