drivers/s390/cio/eadm_sch.c | 3 +--
drivers/s390/net/qeth_l2_main.c | 5 +----
drivers/s390/net/qeth_l3_main.c | 5 +----
3 files changed, 3 insertions(+), 10 deletions(-)
diff --git a/drivers/s390/cio/eadm_sch.c b/drivers/s390/cio/eadm_sch.c
index bee8c11..b3f44bc 100644
--- a/drivers/s390/cio/eadm_sch.c
+++ b/drivers/s390/cio/eadm_sch.c
@@ -336,7 +336,6 @@ static int eadm_subchannel_sch_event(struct subchannel *sch, int process)
struct eadm_private *private;
unsigned long flags;
- int ret = 0;
spin_lock_irqsave(sch->lock, flags);
if (!device_is_registered(&sch->dev))
@@ -356,7 +355,7 @@ static int eadm_subchannel_sch_event(struct subchannel *sch, int process)
out_unlock:
spin_unlock_irqrestore(sch->lock, flags);
- return ret;
+ return 0;
static struct css_device_id eadm_subchannel_ids[] = {
diff --git a/drivers/s390/net/qeth_l2_main.c b/drivers/s390/net/qeth_l2_main.c
index 2e65b98..a855669 100644
--- a/drivers/s390/net/qeth_l2_main.c
+++ b/drivers/s390/net/qeth_l2_main.c
@@ -390,10 +390,8 @@ static int qeth_l2_vlan_rx_kill_vid(struct net_device *dev,
return rc;
-static int qeth_l2_stop_card(struct qeth_card *card, int recovery_mode)
+static void qeth_l2_stop_card(struct qeth_card *card, int recovery_mode)
- int rc = 0;
QETH_DBF_TEXT(SETUP , 2, "stopcard");
QETH_DBF_HEX(SETUP, 2, &card, sizeof(void *));
@@ -427,7 +425,6 @@ static int qeth_l2_stop_card(struct qeth_card *card, int recovery_mode)
qeth_clear_cmd_buffers(&card->read);
qeth_clear_cmd_buffers(&card->write);
- return rc;
static int qeth_l2_process_inbound_buffer(struct qeth_card *card,
diff --git a/drivers/s390/net/qeth_l3_main.c b/drivers/s390/net/qeth_l3_main.c
index 70eb2f6..a1aaa36 100644
--- a/drivers/s390/net/qeth_l3_main.c
+++ b/drivers/s390/net/qeth_l3_main.c
@@ -2158,10 +2158,8 @@ static struct qeth_card *qeth_l3_get_card_from_dev(struct net_device *dev)
return card ;
-static int qeth_l3_stop_card(struct qeth_card *card, int recovery_mode)
+static void qeth_l3_stop_card(struct qeth_card *card, int recovery_mode)
- int rc = 0;
QETH_DBF_TEXT(SETUP, 2, "stopcard");
@@ -2196,7 +2194,6 @@ static int qeth_l3_stop_card(struct qeth_card *card, int recovery_mode)
- return rc;
