[media] Staging: media: lirc: use USB API functions rather than constants
Author: Shraddha Barke <shraddha.6596@gmail.com>
This patch introduces the use of the function usb_endpoint_type.
The Coccinelle semantic patch that makes these changes is as follows:
@@ struct usb_endpoint_descriptor *epd; @@
- (epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\))
+ usb_endpoint_type(epd)
Signed-off-by: Shraddha Barke
Signed-off-by: Mauro Carvalho Chehab
 drivers/staging/media/lirc/lirc_imon.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/media/lirc/lirc_imon.c b/drivers/staging/media/lirc/lirc_imon.c
index 05d47dc..534b810 100644
--- a/drivers/staging/media/lirc/lirc_imon.c
+++ b/drivers/staging/media/lirc/lirc_imon.c
@@ -739,7 +739,7 @@ static int imon_probe(struct usb_interface *interface,
 		ep = &iface_desc->endpoint[i].desc;
 		ep_dir = ep->bEndpointAddress & USB_ENDPOINT_DIR_MASK;
-		ep_type = ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK;
+		ep_type = usb_endpoint_type(ep);
 		if (!ir_ep_found &&
 			ep_dir == USB_DIR_IN &&
