Staging: rtl8192e: Use put_unaligned_le16
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le16.
This is done using Coccinelle and semantic patch used is as follows:
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le16(y);
  <+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le16(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Here, to be compatible with the change header file is added too.
Signed-off-by: Vaishali Thakkar
Reviewed-by: Arnd Bergmann
 drivers/staging/rtl8192e/rtl819x_BAProc.c | 23 +++++++++++------------
 1 file changed, 11 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl819x_BAProc.c b/drivers/staging/rtl8192e/rtl819x_BAProc.c
index 2866c12..66ea791 100644
--- a/drivers/staging/rtl8192e/rtl819x_BAProc.c
+++ b/drivers/staging/rtl8192e/rtl819x_BAProc.c
@@ -16,6 +16,7 @@
  * Contact Information:
  * wlanfae <wlanfae@realtek.com>
+#include <linux/unaligned/access_ok.h>
 #include "rtllib.h"
 #include "rtl819x_BA.h"
@@ -79,7 +80,6 @@ static struct sk_buff *rtllib_ADDBA(struct rtllib_device *ieee, u8 *Dst,
 	struct sk_buff *skb = NULL;
 	 struct rtllib_hdr_3addr *BAReq = NULL;
 	u8 *tag = NULL;
-	__le16 tmp = 0;
 	u16 len = ieee->tx_headroom + 9;
 	RTLLIB_DEBUG(RTLLIB_DL_TRACE | RTLLIB_DL_BA, "========>%s(), frame(%d)"
@@ -115,15 +115,15 @@ static struct sk_buff *rtllib_ADDBA(struct rtllib_device *ieee, u8 *Dst,
 	if (ACT_ADDBARSP == type) {
 		RT_TRACE(COMP_DBG, "====>to send ADDBARSP\n");
-		tmp = cpu_to_le16(StatusCode);
-		memcpy(tag, (u8 *)&tmp, 2);
+		put_unaligned_le16(StatusCode, tag);
 		tag += 2;
-	tmp = cpu_to_le16(pBA->BaParamSet.shortData);
+	put_unaligned_le16(pBA->BaParamSet.shortData, tag);
 	tag += 2;
-	tmp = cpu_to_le16(pBA->BaTimeoutValue);
+	put_unaligned_le16(pBA->BaTimeoutValue, tag);
 	tag += 2;
 	if (ACT_ADDBAREQ == type) {
@@ -143,7 +143,6 @@ static struct sk_buff *rtllib_DELBA(struct rtllib_device *ieee, u8 *dst,
 	 struct rtllib_hdr_3addr *Delba = NULL;
 	u8 *tag = NULL;
-	__le16 tmp = 0;
 	u16 len = 6 + ieee->tx_headroom;
 	if (net_ratelimit())
@@ -178,11 +177,11 @@ static struct sk_buff *rtllib_DELBA(struct rtllib_device *ieee, u8 *dst,
 	*tag++ = ACT_CAT_BA;
 	*tag++ = ACT_DELBA;
-	tmp = cpu_to_le16(DelbaParamSet.shortData);
+	put_unaligned_le16(DelbaParamSet.shortData, tag);
 	tag += 2;
-	tmp = cpu_to_le16(ReasonCode);
+	put_unaligned_le16(ReasonCode, tag);
 	tag += 2;
 	RTLLIB_DEBUG_DATA(RTLLIB_DL_DATA|RTLLIB_DL_BA, skb->data, skb->len);
BtrLinux
Privacy Overview
