Staging: rtl8192u: Use put_unaligned_le16
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le16.
This is done using Coccinelle and semantic patch used is as follows:
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le16(y);
<+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le16(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Here, unnecessory comment after change is removed too.
This patch also fixes sparse warnings in file ieeee80211_softmac.c.
Signed-off-by: Vaishali Thakkar
drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c | 7 +++----
1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 9b87408..d147187 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -804,12 +804,11 @@ static struct sk_buff *ieee80211_probe_resp(struct ieee80211_device *ieee, u8 *d
*(tag++) = ieee->current_network.channel;
if(atim_len){
- u16 val16;
*(tag++) = MFIE_TYPE_IBSS_SET;
*(tag++) = 2;
- //*((u16*)(tag)) = cpu_to_le16(ieee->current_network.atim_window);
- val16 = cpu_to_le16(ieee->current_network.atim_window);
- memcpy((u8 *)tag, (u8 *)&val16, 2);
+ put_unaligned_le16(ieee->current_network.atim_window,
+ (u8 *)tag);
tag+=2;
if(atim_len){
- u16 val16;
*(tag++) = 2;
+ (u8 *)tag);
tag+=2;
