Staging: lustre: Use put_unaligned_le64
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function put_unaligned_le64.
This is done using Coccinelle and semantic patch used is as follows:
@@ identifier tmp; expression ptr; expression y,e; type T; @@
- tmp = cpu_to_le64(y);
<+... when != tmp
- memcpy(ptr, (T)&tmp, ...);
+ put_unaligned_le64(y,ptr);
? tmp = e
@@ type T; identifier tmp; @@
- T tmp;
...when != tmp
Signed-off-by: Vaishali Thakkar
drivers/staging/lustre/lustre/obdclass/debug.c | 12 +++++-------
1 file changed, 5 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/debug.c b/drivers/staging/lustre/lustre/obdclass/debug.c
index d0f8f87..9c934e6 100644
--- a/drivers/staging/lustre/lustre/obdclass/debug.c
+++ b/drivers/staging/lustre/lustre/obdclass/debug.c
@@ -40,6 +40,7 @@
#define DEBUG_SUBSYSTEM D_OTHER
+#include <linux/unaligned/access_ok.h>
#include "../include/obd_support.h"
#include "../include/lustre_debug.h"
@@ -60,14 +61,11 @@ int block_debug_setup(void *addr, int len, __u64 off, __u64 id)
LASSERT(addr);
- off = cpu_to_le64 (off);
- id = cpu_to_le64 (id);
- memcpy(addr, (char *)&off, LPDS);
- memcpy(addr + LPDS, (char *)&id, LPDS);
+ put_unaligned_le64(off, addr);
+ put_unaligned_le64(id, addr+LPDS);
addr += len - LPDS - LPDS;
return 0;
@@ -40,6 +40,7 @@
LASSERT(addr);
return 0;
