Staging: rtl8192e: Drop unnecessary NULL test
The result of container_of should not be NULL.  In particular, in this case
the argument to the enclosing function has passed though INIT_WORK, which
dereferences it, implying that its container cannot be NULL.
A simplified version of the semantic patch that makes this change is as
follows:
(http://www.emn.fr/x-info/coccinelle/)
identifier fn,work,x,fld;
type T;
expression E1,E2;
statement S;
static fn(struct work_struct *work) {
  ... when != work = E1
  x = container_of(work,T,fld)
  ... when != x = E2
- if (x == NULL) S
Signed-off-by: Julia Lawall
 drivers/staging/rtl8192e/r8192E_core.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/staging/rtl8192e/r8192E_core.c b/drivers/staging/rtl8192e/r8192E_core.c
index 681488b..d4fa654 100644
--- a/drivers/staging/rtl8192e/r8192E_core.c
+++ b/drivers/staging/rtl8192e/r8192E_core.c
@@ -1763,8 +1763,6 @@ static void rtl8192_qos_activate(struct work_struct * work)
 	u8  u1bAIFS;
 	u32 u4bAcParam;
         int i;
-        if (priv == NULL)
-                return;
         mutex_lock(&priv->mutex);
         if(priv->ieee80211->state != IEEE80211_LINKED)
BtrLinux
Privacy Overview
