[S390] drivers/s390: put NULL test before dereference
If the NULL test on block is needed, it should be before the dereference of
the base field.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
expression E1,E2;
identifier fld;
statement S1,S2;
E1 = E2->fld;
if (E1 == NULL) S1 else S2
*if (E2 == NULL) S1 else S2
Signed-off-by: Julia Lawall
Signed-off-by: Martin Schwidefsky
 drivers/s390/block/dasd.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/s390/block/dasd.c b/drivers/s390/block/dasd.c
index 7498366..3f62dd5 100644
--- a/drivers/s390/block/dasd.c
+++ b/drivers/s390/block/dasd.c
@@ -2135,9 +2135,9 @@ static int dasd_getgeo(struct block_device *bdev, struct hd_geometry *geo)
 	struct dasd_device *base;
 	block = bdev->bd_disk->private_data;
-	base = block->base;
 	if (!block)
 		return -ENODEV;
+	base = block->base;
 	if (!base->discipline ||
 	    !base->discipline->fill_geometry)
