drivers/net/wan: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/wan/hdlc_ppp.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/net/wan/hdlc_ppp.c b/drivers/net/wan/hdlc_ppp.c
index 72a7cda..b9b9d6b 100644
--- a/drivers/net/wan/hdlc_ppp.c
+++ b/drivers/net/wan/hdlc_ppp.c
@@ -389,6 +389,7 @@ static void ppp_cp_parse_cr(struct net_device *dev, u16 pid, u8 id,
 	for (opt = data; len; len -= opt[1], opt += opt[1]) {
 		if (len < 2 || len < opt[1]) {
 			dev->stats.rx_errors++;
+			kfree(out);
 			return; /* bad packet, drop silently */
