staging: lustre: remove initialization of static ints
Author: Supriya Karanth <iskaranth@gmail.com>
static ints are initialized to 0 by the compiler.
Explicit initialization is not necessary.
Found by checkpatch.pl - ERROR: do not initialise statics to 0 or NULL
changes made using coccinelle script:
type T;
identifier var;
-static T var = 0;
+static T var;
Signed-off-by: Supriya Karanth
drivers/staging/lustre/lustre/libcfs/linux/linux-proc.c | 2 +-
drivers/staging/lustre/lustre/libcfs/tracefile.c | 2 +-
drivers/staging/lustre/lustre/llite/statahead.c | 2 +-
drivers/staging/lustre/lustre/mgc/mgc_request.c | 2 +-
drivers/staging/lustre/lustre/obdclass/genops.c | 2 +-
drivers/staging/lustre/lustre/obdclass/lprocfs_status.c | 2 +-
drivers/staging/lustre/lustre/obdclass/lu_object.c | 2 +-
drivers/staging/lustre/lustre/ptlrpc/pack_generic.c | 2 +-
drivers/staging/lustre/lustre/ptlrpc/pinger.c | 2 +-
drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c | 2 +-
10 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/staging/lustre/lustre/libcfs/linux/linux-proc.c b/drivers/staging/lustre/lustre/libcfs/linux/linux-proc.c
index 0f65929..3100cb1 100644
--- a/drivers/staging/lustre/lustre/libcfs/linux/linux-proc.c
+++ b/drivers/staging/lustre/lustre/libcfs/linux/linux-proc.c
@@ -165,7 +165,7 @@ static int proc_dobitmasks(struct ctl_table *table, int write,
__proc_dobitmasks);
-static int min_watchdog_ratelimit = 0; /* disable ratelimiting */
+static int min_watchdog_ratelimit; /* disable ratelimiting */
static int max_watchdog_ratelimit = (24*60*60); /* limit to once per day */
static int __proc_dump_kernel(void *data, int write,
diff --git a/drivers/staging/lustre/lustre/libcfs/tracefile.c b/drivers/staging/lustre/lustre/libcfs/tracefile.c
index f8d8a2f..c86394f 100644
--- a/drivers/staging/lustre/lustre/libcfs/tracefile.c
+++ b/drivers/staging/lustre/lustre/libcfs/tracefile.c
@@ -53,7 +53,7 @@ char cfs_tracefile[TRACEFILE_NAME_SIZE];
long long cfs_tracefile_size = CFS_TRACEFILE_SIZE;
static struct tracefiled_ctl trace_tctl;
struct mutex cfs_trace_thread_mutex;
-static int thread_running = 0;
+static int thread_running;
static atomic_t cfs_tage_allocated = ATOMIC_INIT(0);
diff --git a/drivers/staging/lustre/lustre/llite/statahead.c b/drivers/staging/lustre/lustre/llite/statahead.c
index 6ad9dd0..fe732fa 100644
--- a/drivers/staging/lustre/lustre/llite/statahead.c
+++ b/drivers/staging/lustre/lustre/llite/statahead.c
@@ -84,7 +84,7 @@ struct ll_sa_entry {
struct qstr se_qstr;
-static unsigned int sai_generation = 0;
+static unsigned int sai_generation;
static DEFINE_SPINLOCK(sai_generation_lock);
static inline int ll_sa_entry_unhashed(struct ll_sa_entry *entry)
diff --git a/drivers/staging/lustre/lustre/mgc/mgc_request.c b/drivers/staging/lustre/lustre/mgc/mgc_request.c
index b244575..0375bfe 100644
--- a/drivers/staging/lustre/lustre/mgc/mgc_request.c
+++ b/drivers/staging/lustre/lustre/mgc/mgc_request.c
@@ -479,7 +479,7 @@ int lprocfs_mgc_rd_ir_state(struct seq_file *m, void *data)
#define RQ_NOW 0x2
#define RQ_LATER 0x4
#define RQ_STOP 0x8
-static int rq_state = 0;
+static int rq_state;
static wait_queue_head_t rq_waitq;
static DECLARE_COMPLETION(rq_exit);
diff --git a/drivers/staging/lustre/lustre/obdclass/genops.c b/drivers/staging/lustre/lustre/obdclass/genops.c
index 8250821..6d440b4 100644
--- a/drivers/staging/lustre/lustre/obdclass/genops.c
+++ b/drivers/staging/lustre/lustre/obdclass/genops.c
@@ -1559,7 +1559,7 @@ void obd_exports_barrier(struct obd_device *obd)
EXPORT_SYMBOL(obd_exports_barrier);
/* Total amount of zombies to be destroyed */
-static int zombies_count = 0;
+static int zombies_count;
* kill zombie imports and exports
diff --git a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
index 55e8081..c171c6c 100644
--- a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
+++ b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
@@ -223,7 +223,7 @@ EXPORT_SYMBOL(lprocfs_write_frac_helper);
#if defined (CONFIG_PROC_FS)
-static int lprocfs_no_percpu_stats = 0;
+static int lprocfs_no_percpu_stats;
module_param(lprocfs_no_percpu_stats, int, 0644);
MODULE_PARM_DESC(lprocfs_no_percpu_stats, "Do not alloc percpu data for lprocfs stats");
diff --git a/drivers/staging/lustre/lustre/obdclass/lu_object.c b/drivers/staging/lustre/lustre/obdclass/lu_object.c
index d2311f2..20c0779 100644
--- a/drivers/staging/lustre/lustre/obdclass/lu_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/lu_object.c
@@ -1308,7 +1308,7 @@ static DEFINE_SPINLOCK(lu_keys_guard);
* lu_context_refill(). No locking is provided, as initialization and shutdown
* are supposed to be externally serialized.
-static unsigned key_set_version = 0;
+static unsigned key_set_version;
* Register new key.
diff --git a/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c b/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c
index 2f45f765..eb6ff90 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c
@@ -117,7 +117,7 @@ EXPORT_SYMBOL(lustre_msg_check_version);
/* early reply size */
int lustre_msg_early_size(void)
- static int size = 0;
+ static int size;
if (!size) {
/* Always reply old ptlrpc_body_v2 to keep interoprability
* with the old client (< 2.3) which doesn't have pb_jobid
diff --git a/drivers/staging/lustre/lustre/ptlrpc/pinger.c b/drivers/staging/lustre/lustre/ptlrpc/pinger.c
index 340d98a..9dbda93 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/pinger.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/pinger.c
@@ -545,7 +545,7 @@ void ptlrpc_pinger_wake_up(void)
#define PET_READY 1
#define PET_TERMINATE 2
-static int pet_refcount = 0;
+static int pet_refcount;
static int pet_state;
static wait_queue_head_t pet_waitq;
LIST_HEAD(pet_list);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
index 4621b71..8f7be84 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
@@ -85,7 +85,7 @@ MODULE_PARM_DESC(ptlrpcd_bind_policy, "Ptlrpcd threads binding mode.");
static struct ptlrpcd *ptlrpcds;
struct mutex ptlrpcd_mutex;
-static int ptlrpcd_users = 0;
+static int ptlrpcd_users;
void ptlrpcd_wake(struct ptlrpc_request *req)
__proc_dobitmasks);
#define RQ_NOW 0x2
#define RQ_STOP 0x8
* Register new key.
+ static int size;
if (!size) {
#define PET_READY 1
