drivers/staging/rtl8712/mlme_linux.c | 48 +++++++++++++++---------------
drivers/staging/rtl8712/os_intfs.c | 4 +--
drivers/staging/rtl8712/osdep_service.h | 9 ------
drivers/staging/rtl8712/recv_linux.c | 11 ++++---
drivers/staging/rtl8712/rtl8712_led.c | 3 +-
drivers/staging/rtl8712/rtl871x_pwrctrl.c | 8 ++---
drivers/staging/rtl8712/rtl871x_security.c | 4 +--
drivers/staging/rtl8712/rtl871x_security.h | 2 +-
8 files changed, 40 insertions(+), 49 deletions(-)
diff --git a/drivers/staging/rtl8712/mlme_linux.c b/drivers/staging/rtl8712/mlme_linux.c
index 53999e8..8c5a475 100644
--- a/drivers/staging/rtl8712/mlme_linux.c
+++ b/drivers/staging/rtl8712/mlme_linux.c
@@ -32,39 +32,39 @@
#include "drv_types.h"
#include "mlme_osdep.h"
-static void sitesurvey_ctrl_handler(void *FunctionContext)
+static void sitesurvey_ctrl_handler(unsigned long data)
- struct _adapter *adapter = (struct _adapter *)FunctionContext;
+ struct _adapter *adapter = (struct _adapter *)data;
_r8712_sitesurvey_ctrl_handler(adapter);
mod_timer(&adapter->mlmepriv.sitesurveyctrl.sitesurvey_ctrl_timer,
jiffies + msecs_to_jiffies(3000));
-static void join_timeout_handler (void *FunctionContext)
+static void join_timeout_handler (unsigned long data)
_r8712_join_timeout_handler(adapter);
-static void _scan_timeout_handler (void *FunctionContext)
+static void _scan_timeout_handler (unsigned long data)
r8712_scan_timeout_handler(adapter);
-static void dhcp_timeout_handler (void *FunctionContext)
+static void dhcp_timeout_handler (unsigned long data)
_r8712_dhcp_timeout_handler(adapter);
-static void wdg_timeout_handler (void *FunctionContext)
+static void wdg_timeout_handler (unsigned long data)
_r8712_wdg_timeout_handler(adapter);
@@ -76,17 +76,17 @@ void r8712_init_mlme_timer(struct _adapter *padapter)
struct mlme_priv *pmlmepriv = &padapter->mlmepriv;
- _init_timer(&(pmlmepriv->assoc_timer), padapter->pnetdev,
- join_timeout_handler, (pmlmepriv->nic_hdl));
- _init_timer(&(pmlmepriv->sitesurveyctrl.sitesurvey_ctrl_timer),
- padapter->pnetdev, sitesurvey_ctrl_handler,
- (u8 *)(pmlmepriv->nic_hdl));
- _init_timer(&(pmlmepriv->scan_to_timer), padapter->pnetdev,
- _scan_timeout_handler, (pmlmepriv->nic_hdl));
- _init_timer(&(pmlmepriv->dhcp_timer), padapter->pnetdev,
- dhcp_timeout_handler, (u8 *)(pmlmepriv->nic_hdl));
- _init_timer(&(pmlmepriv->wdg_timer), padapter->pnetdev,
- wdg_timeout_handler, (u8 *)(pmlmepriv->nic_hdl));
+ setup_timer(&pmlmepriv->assoc_timer, join_timeout_handler,
+ (unsigned long)padapter);
+ setup_timer(&pmlmepriv->sitesurveyctrl.sitesurvey_ctrl_timer,
+ sitesurvey_ctrl_handler,
+ setup_timer(&pmlmepriv->scan_to_timer, _scan_timeout_handler,
+ setup_timer(&pmlmepriv->dhcp_timer, dhcp_timeout_handler,
+ setup_timer(&pmlmepriv->wdg_timer, wdg_timeout_handler,
void r8712_os_indicate_connect(struct _adapter *adapter)
@@ -118,9 +118,9 @@ void r8712_os_indicate_disconnect(struct _adapter *adapter)
btkip_countermeasure;
memset((unsigned char *)&adapter->securitypriv, 0,
sizeof(struct security_priv));
- _init_timer(&(adapter->securitypriv.tkip_timer),
- adapter->pnetdev, r8712_use_tkipkey_handler,
- adapter);
+ setup_timer(&adapter->securitypriv.tkip_timer,
+ r8712_use_tkipkey_handler,
+ (unsigned long)adapter);
/* Restore the PMK information to securitypriv structure
* for the following connection. */
memcpy(&adapter->securitypriv.PMKIDList[0],
diff --git a/drivers/staging/rtl8712/os_intfs.c b/drivers/staging/rtl8712/os_intfs.c
index 64cdcee..ebfb29e 100644
--- a/drivers/staging/rtl8712/os_intfs.c
+++ b/drivers/staging/rtl8712/os_intfs.c
@@ -323,8 +323,8 @@ u8 r8712_init_drv_sw(struct _adapter *padapter)
_r8712_init_recv_priv(&padapter->recvpriv, padapter);
memset((unsigned char *)&padapter->securitypriv, 0,
- _init_timer(&(padapter->securitypriv.tkip_timer), padapter->pnetdev,
- r8712_use_tkipkey_handler, padapter);
+ setup_timer(&padapter->securitypriv.tkip_timer,
+ r8712_use_tkipkey_handler, (unsigned long)padapter);
_r8712_init_sta_priv(&padapter->stapriv);
padapter->stapriv.padapter = padapter;
r8712_init_bcmc_stainfo(padapter);
diff --git a/drivers/staging/rtl8712/osdep_service.h b/drivers/staging/rtl8712/osdep_service.h
index 54c4c47..c6dc362 100644
--- a/drivers/staging/rtl8712/osdep_service.h
+++ b/drivers/staging/rtl8712/osdep_service.h
@@ -60,15 +60,6 @@ struct __queue {
#define LIST_CONTAINOR(ptr, type, member) \
((type *)((char *)(ptr)-(SIZE_T)(&((type *)0)->member)))
-static inline void _init_timer(struct timer_list *ptimer,
- struct net_device *padapter,
- void *pfunc, void *cntx)
- ptimer->function = pfunc;
- ptimer->data = (addr_t)cntx;
- init_timer(ptimer);
static inline void _cancel_timer(struct timer_list *ptimer, u8 *bcancelled)
del_timer(ptimer);
diff --git a/drivers/staging/rtl8712/recv_linux.c b/drivers/staging/rtl8712/recv_linux.c
index 3640dd4..799a0f9 100644
--- a/drivers/staging/rtl8712/recv_linux.c
+++ b/drivers/staging/rtl8712/recv_linux.c
@@ -137,18 +137,17 @@ _recv_indicatepkt_drop:
precvpriv->rx_drop++;
-static void _r8712_reordering_ctrl_timeout_handler (void *FunctionContext)
+static void _r8712_reordering_ctrl_timeout_handler (unsigned long data)
struct recv_reorder_ctrl *preorder_ctrl =
- (struct recv_reorder_ctrl *)FunctionContext;
+ (struct recv_reorder_ctrl *)data;
r8712_reordering_ctrl_timeout_handler(preorder_ctrl);
void r8712_init_recv_timer(struct recv_reorder_ctrl *preorder_ctrl)
- struct _adapter *padapter = preorder_ctrl->padapter;
- _init_timer(&(preorder_ctrl->reordering_ctrl_timer), padapter->pnetdev,
- _r8712_reordering_ctrl_timeout_handler, preorder_ctrl);
+ setup_timer(&preorder_ctrl->reordering_ctrl_timer,
+ _r8712_reordering_ctrl_timeout_handler,
+ (unsigned long)preorder_ctrl);
diff --git a/drivers/staging/rtl8712/rtl8712_led.c b/drivers/staging/rtl8712/rtl8712_led.c
index 0c7dfee..6085689 100644
--- a/drivers/staging/rtl8712/rtl8712_led.c
+++ b/drivers/staging/rtl8712/rtl8712_led.c
@@ -97,7 +97,8 @@ static void InitLed871x(struct _adapter *padapter, struct LED_871x *pLed,
pLed->bLedBlinkInProgress = false;
pLed->BlinkTimes = 0;
pLed->BlinkingLedState = LED_UNKNOWN;
- _init_timer(&(pLed->BlinkTimer), nic, BlinkTimerCallback, pLed);
+ setup_timer(&pLed->BlinkTimer, BlinkTimerCallback,
+ (unsigned long)pLed);
INIT_WORK(&pLed->BlinkWorkItem, BlinkWorkItemCallback);
diff --git a/drivers/staging/rtl8712/rtl871x_pwrctrl.c b/drivers/staging/rtl8712/rtl871x_pwrctrl.c
index ed2844d..ea732ee 100644
--- a/drivers/staging/rtl8712/rtl871x_pwrctrl.c
+++ b/drivers/staging/rtl8712/rtl871x_pwrctrl.c
@@ -165,9 +165,9 @@ static void rpwm_workitem_callback(struct work_struct *work)
-static void rpwm_check_handler (void *FunctionContext)
+static void rpwm_check_handler (unsigned long data)
_rpwm_check_handler(adapter);
@@ -186,8 +186,8 @@ void r8712_init_pwrctrl_priv(struct _adapter *padapter)
r8712_write8(padapter, 0x1025FE58, 0);
INIT_WORK(&pwrctrlpriv->SetPSModeWorkItem, SetPSModeWorkItemCallback);
INIT_WORK(&pwrctrlpriv->rpwm_workitem, rpwm_workitem_callback);
- _init_timer(&(pwrctrlpriv->rpwm_check_timer),
- padapter->pnetdev, rpwm_check_handler, (u8 *)padapter);
+ setup_timer(&pwrctrlpriv->rpwm_check_timer, rpwm_check_handler,
diff --git a/drivers/staging/rtl8712/rtl871x_security.c b/drivers/staging/rtl8712/rtl871x_security.c
index 743dd936..4d5a288 100644
--- a/drivers/staging/rtl8712/rtl871x_security.c
+++ b/drivers/staging/rtl8712/rtl871x_security.c
@@ -1392,9 +1392,9 @@ u32 r8712_aes_decrypt(struct _adapter *padapter, u8 *precvframe)
return _SUCCESS;
-void r8712_use_tkipkey_handler(void *FunctionContext)
+void r8712_use_tkipkey_handler(unsigned long data)
- struct _adapter *padapter = (struct _adapter *)FunctionContext;
+ struct _adapter *padapter = (struct _adapter *)data;
padapter->securitypriv.busetkipkey = true;
diff --git a/drivers/staging/rtl8712/rtl871x_security.h b/drivers/staging/rtl8712/rtl871x_security.h
index c732aea..2295f0e 100644
--- a/drivers/staging/rtl8712/rtl871x_security.h
+++ b/drivers/staging/rtl8712/rtl871x_security.h
@@ -216,7 +216,7 @@ void r8712_wep_encrypt(struct _adapter *padapter, u8 *pxmitframe);
u32 r8712_aes_decrypt(struct _adapter *padapter, u8 *precvframe);
u32 r8712_tkip_decrypt(struct _adapter *padapter, u8 *precvframe);
void r8712_wep_decrypt(struct _adapter *padapter, u8 *precvframe);
-void r8712_use_tkipkey_handler(void *FunctionContext);
+void r8712_use_tkipkey_handler(unsigned long data);
#endif /*__RTL871X_SECURITY_H_ */ |
