staging: rtl8192u: ieee80211: replace memset(x,0,ETH_ALEN) by eth_zero_addr(x)
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
eth_zero_addr() is a wrapper function for memset if 0 is going to
be assigned to a mac address. The replacement was done by the
following coccinelle script:
@header@
#include
@eth_zero_addr@
expression e;
-memset(e,0,ETH_ALEN);
+eth_zero_addr(e);
@eth_broadcast_addr@
identifier e;
-memset(e,\(0xff\|0xFF\|255\),ETH_ALEN);
+eth_broadcast_addr(e);
@linux_header depends on !header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
@special_header depends on !header && !linux_header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
@custom_header depends on !header && !linux_header && !special_header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
Signed-off-by: Aya Mahfouz
drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
index 644368d..dcfa5ab 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
@@ -121,7 +121,7 @@ int ieee80211_wx_get_wap(struct ieee80211_device *ieee,
ieee->state != IEEE80211_LINKED_SCANNING &&
ieee->wap_set == 0)
- memset(wrqu->ap_addr.sa_data, 0, ETH_ALEN);
+ eth_zero_addr(wrqu->ap_addr.sa_data);
else
memcpy(wrqu->ap_addr.sa_data,
ieee->current_network.bssid, ETH_ALEN); |
ieee->wap_set == 0)
else
