pcmcia: Use setup_timer and mod_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of functions setup_timer
and mod_timer.
This is done using Coccinelle and semantic patch used
for this as follows:
expression x,y,z,a,b;
-init_timer (&x);
+setup_timer (&x, y, z);
+mod_timer (&a, b);
-x.function = y;
-x.data = z;
-x.expires = b;
-add_timer(&a);
Signed-off-by: Vaishali Thakkar
drivers/pcmcia/pd6729.c | 8 +++-----
drivers/pcmcia/yenta_socket.c | 8 +++-----
2 files changed, 6 insertions(+), 10 deletions(-)
diff --git a/drivers/pcmcia/pd6729.c b/drivers/pcmcia/pd6729.c
index 34ace48..0f70b4d 100644
--- a/drivers/pcmcia/pd6729.c
+++ b/drivers/pcmcia/pd6729.c
@@ -707,11 +707,9 @@ static int pd6729_pci_probe(struct pci_dev *dev,
} else {
/* poll Card status change */
- init_timer(&socket->poll_timer);
- socket->poll_timer.function = pd6729_interrupt_wrapper;
- socket->poll_timer.data = (unsigned long)socket;
- socket->poll_timer.expires = jiffies + HZ;
- add_timer(&socket->poll_timer);
+ setup_timer(&socket->poll_timer, pd6729_interrupt_wrapper,
+ (unsigned long)socket);
+ mod_timer(&socket->poll_timer, jiffies + HZ);
for (i = 0; i < MAX_SOCKETS; i++) {
diff --git a/drivers/pcmcia/yenta_socket.c b/drivers/pcmcia/yenta_socket.c
index 8a23ccb..965bd84 100644
--- a/drivers/pcmcia/yenta_socket.c
+++ b/drivers/pcmcia/yenta_socket.c
@@ -1236,11 +1236,9 @@ static int yenta_probe(struct pci_dev *dev, const struct pci_device_id *id)
if (!socket->cb_irq || request_irq(socket->cb_irq, yenta_interrupt, IRQF_SHARED, "yenta", socket)) {
/* No IRQ or request_irq failed. Poll */
socket->cb_irq = 0; /* But zero is a valid IRQ number. */
- socket->poll_timer.function = yenta_interrupt_wrapper;
+ setup_timer(&socket->poll_timer, yenta_interrupt_wrapper,
dev_printk(KERN_INFO, &dev->dev,
"no PCI IRQ, CardBus support disabled for this "
"socket.\n"); |
} else {
"socket.\n");
