pcmcia: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of function setup_timer.
This is done using Coccinelle and semantic patch used is
as follows:
expression x,y,z;
- init_timer (&x);
+ setup_timer (&x, y, z);
- x.function = y;
- x.data = z;
Signed-off-by: Vaishali Thakkar
drivers/pcmcia/omap_cf.c | 4 +---
drivers/pcmcia/soc_common.c | 5 ++---
2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/pcmcia/omap_cf.c b/drivers/pcmcia/omap_cf.c
index 8170102..4e2f501 100644
--- a/drivers/pcmcia/omap_cf.c
+++ b/drivers/pcmcia/omap_cf.c
@@ -220,9 +220,7 @@ static int __init omap_cf_probe(struct platform_device *pdev)
cf = kzalloc(sizeof *cf, GFP_KERNEL);
if (!cf)
return -ENOMEM;
- init_timer(&cf->timer);
- cf->timer.function = omap_cf_timer;
- cf->timer.data = (unsigned long) cf;
+ setup_timer(&cf->timer, omap_cf_timer, (unsigned long)cf);
cf->pdev = pdev;
platform_set_drvdata(pdev, cf);
diff --git a/drivers/pcmcia/soc_common.c b/drivers/pcmcia/soc_common.c
index 933f465..eed5e9c 100644
--- a/drivers/pcmcia/soc_common.c
+++ b/drivers/pcmcia/soc_common.c
@@ -726,9 +726,8 @@ int soc_pcmcia_add_one(struct soc_pcmcia_socket *skt)
int ret;
- init_timer(&skt->poll_timer);
- skt->poll_timer.function = soc_common_pcmcia_poll_event;
- skt->poll_timer.data = (unsigned long)skt;
+ setup_timer(&skt->poll_timer, soc_common_pcmcia_poll_event,
+ (unsigned long)skt);
skt->poll_timer.expires = jiffies + SOC_PCMCIA_POLL_PERIOD;
ret = request_resource(&iomem_resource, &skt->res_skt); |
if (!cf)
return -ENOMEM;
cf->pdev = pdev;
int ret;
