drivers/net: Use setup_timer and mod_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch introduces the use of functions setup_timer
and mod_timer.
This is done using Coccinelle and semantic patch used
for this as follows:
expression x,y,z,a,b;
-init_timer (&x);
+setup_timer (&x, y, z);
+mod_timer (&a, b);
-x.function = y;
-x.data = z;
-x.expires = b;
-add_timer(&a);
Signed-off-by: Vaishali Thakkar
Signed-off-by: David S. Miller
drivers/net/ethernet/3com/3c589_cs.c | 7 ++-----
1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/net/ethernet/3com/3c589_cs.c b/drivers/net/ethernet/3com/3c589_cs.c
index f18647c..c5a3205 100644
--- a/drivers/net/ethernet/3com/3c589_cs.c
+++ b/drivers/net/ethernet/3com/3c589_cs.c
@@ -518,11 +518,8 @@ static int el3_open(struct net_device *dev)
netif_start_queue(dev);
tc589_reset(dev);
- init_timer(&lp->media);
- lp->media.function = media_check;
- lp->media.data = (unsigned long) dev;
- lp->media.expires = jiffies + HZ;
- add_timer(&lp->media);
+ setup_timer(&lp->media, media_check, (unsigned long)dev);
+ mod_timer(&lp->media, jiffies + HZ);
dev_dbg(&link->dev, "%s: opened, status %4.4x.\n",
dev->name, inw(dev->base_addr + EL3_STATUS)); |
tc589_reset(dev);
