PCI: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
Since the subsequent code that could provoke an error does not use the
allocated data, the allocation is just moved below it.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f = E
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Reviewed-by: Matthew Wilcox
Reviewed-by: Kenji Kaneshige
Signed-off-by: Jesse Barnes
 drivers/pci/hotplug/pciehp_acpi.c | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/hotplug/pciehp_acpi.c b/drivers/pci/hotplug/pciehp_acpi.c
index 21734c3..9604801 100644
--- a/drivers/pci/hotplug/pciehp_acpi.c
+++ b/drivers/pci/hotplug/pciehp_acpi.c
@@ -79,14 +79,15 @@ static int __init dummy_probe(struct pcie_device *dev)
 	struct slot *slot, *tmp;
 	struct pci_dev *pdev = dev->port;
 	struct pci_bus *pbus = pdev->subordinate;
-	if (!(slot = kzalloc(sizeof(*slot), GFP_KERNEL)))
-		return -ENOMEM;
 	/* Note: pciehp_detect_mode != PCIEHP_DETECT_ACPI here */
 	if (pciehp_get_hp_hw_control_from_firmware(pdev))
 		return -ENODEV;
 	if (!(pos = pci_find_capability(pdev, PCI_CAP_ID_EXP)))
 		return -ENODEV;
 	pci_read_config_dword(pdev, pos + PCI_EXP_SLTCAP, &slot_cap);
+	slot = kzalloc(sizeof(*slot), GFP_KERNEL);
+	if (!slot)
+		return -ENOMEM;
 	slot->number = slot_cap >> 19;
 	list_for_each_entry(tmp, &dummy_slots, slot_list) {
 		if (tmp->number == slot->number)
BtrLinux
Privacy Overview
