drivers/atm: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f = E
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/atm/solos-pci.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/atm/solos-pci.c b/drivers/atm/solos-pci.c
index 72fc0f7..89d7a6e 100644
--- a/drivers/atm/solos-pci.c
+++ b/drivers/atm/solos-pci.c
@@ -685,6 +685,7 @@ static int fpga_probe(struct pci_dev *dev, const struct pci_device_id *id)
out_release_regions:
pci_release_regions(dev);
out:
+ kfree(card);
return err;
out:
+ kfree(card);
return err;
