[SCSI] lpfc: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f = E
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Acked-by: James Smart
Signed-off-by: James Bottomley
 drivers/scsi/lpfc/lpfc_els.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/scsi/lpfc/lpfc_els.c b/drivers/scsi/lpfc/lpfc_els.c
index a8f30bd..a730248 100644
--- a/drivers/scsi/lpfc/lpfc_els.c
+++ b/drivers/scsi/lpfc/lpfc_els.c
@@ -5258,6 +5258,7 @@ lpfc_send_els_event(struct lpfc_vport *vport,
 			sizeof(struct lpfc_name));
 		break;
 	default:
+		kfree(els_data);
 		return;
 	memcpy(els_data->wwpn, &ndlp->nlp_portname, sizeof(struct lpfc_name));
