net/ipv4/igmp.c: Replace rcu_dereference() with rcu_access_pointer()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The "rcu_dereference()" call is used directly in a condition.
Since its return value is never dereferenced it is recommended to use
"rcu_access_pointer()" instead of "rcu_dereference()".
Therefore, this patch makes the replacement.
The following Coccinelle semantic patch was used:
if(
- rcu_dereference
+ rcu_access_pointer
while(
- rcu_dereference
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: David S. Miller
net/ipv4/igmp.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/ipv4/igmp.c b/net/ipv4/igmp.c
index f10eab4..890c425 100644
--- a/net/ipv4/igmp.c
+++ b/net/ipv4/igmp.c
@@ -2539,7 +2539,7 @@ static int igmp_mc_seq_show(struct seq_file *seq, void *v)
querier = "NONE";
#endif
- if (rcu_dereference(state->in_dev->mc_list) == im) {
+ if (rcu_access_pointer(state->in_dev->mc_list) == im) {
seq_printf(seq, "%d\t%-10s: %5d %7s\n",
state->dev->ifindex, state->dev->name, state->in_dev->mc_count, querier);
querier = "NONE";
#endif
