mac80211: Replace rcu_dereference() with rcu_access_pointer()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
The "rcu_dereference()" calls are used directly in conditions.
Since their return values are never dereferenced it is recommended to
use "rcu_access_pointer()" instead of "rcu_dereference()".
Therefore, this patch makes the replacements.
The following Coccinelle semantic patch was used:
if(
- rcu_dereference
+ rcu_access_pointer
while(
- rcu_dereference
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: Johannes Berg
net/mac80211/mesh_pathtbl.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/net/mac80211/mesh_pathtbl.c b/net/mac80211/mesh_pathtbl.c
index cf032a8..a6699dc 100644
--- a/net/mac80211/mesh_pathtbl.c
+++ b/net/mac80211/mesh_pathtbl.c
@@ -729,7 +729,7 @@ void mesh_plink_broken(struct sta_info *sta)
tbl = rcu_dereference(mesh_paths);
for_each_mesh_entry(tbl, node, i) {
mpath = node->mpath;
- if (rcu_dereference(mpath->next_hop) == sta &&
+ if (rcu_access_pointer(mpath->next_hop) == sta &&
mpath->flags & MESH_PATH_ACTIVE &&
!(mpath->flags & MESH_PATH_FIXED)) {
spin_lock_bh(&mpath->state_lock);
@@ -794,7 +794,7 @@ void mesh_path_flush_by_nexthop(struct sta_info *sta)
tbl = resize_dereference_mesh_paths();
- if (rcu_dereference(mpath->next_hop) == sta) {
+ if (rcu_access_pointer(mpath->next_hop) == sta) {
spin_lock(&tbl->hashwlock[i]);
__mesh_path_del(tbl, node);
spin_unlock(&tbl->hashwlock[i]); |
