bonding: Replace rcu_dereference() with rcu_access_pointer()
Author: Andreea-Cristina Bernat <bernat.ada@gmail.com>
This "rcu_dereference()" call is used directly in a condition.
Since its return value is never dereferenced it is recommended to use
"rcu_access_pointer()" instead of "rcu_dereference()".
Therefore, this patch makes this replacement.
The following Coccinelle semantic patch was used for solving it:
if(
- rcu_dereference
+ rcu_access_pointer
while(
- rcu_dereference
Signed-off-by: Andreea-Cristina Bernat
Signed-off-by: David S. Miller
drivers/net/bonding/bond_alb.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/bonding/bond_alb.c b/drivers/net/bonding/bond_alb.c
index 95dd1f5..73c21e2 100644
--- a/drivers/net/bonding/bond_alb.c
+++ b/drivers/net/bonding/bond_alb.c
@@ -1388,7 +1388,7 @@ static int bond_do_alb_xmit(struct sk_buff *skb, struct bonding *bond,
if (tx_slave && bond_slave_can_tx(tx_slave)) {
- if (tx_slave != rcu_dereference(bond->curr_active_slave)) {
+ if (tx_slave != rcu_access_pointer(bond->curr_active_slave)) {
ether_addr_copy(eth_data->h_source,
tx_slave->dev->dev_addr);
