MIPS: SEAD3: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, the now unnecessary labels out_mem and out are done
away with. The error handling code is moved under if and return 0 is now
at the end of the function.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Tested-by: Markos Chandras
Reviewed-by: Markos Chandras
Cc: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/6977/
Signed-off-by: Ralf Baechle
 arch/mips/mti-sead3/sead3-pic32-i2c-drv.c | 36 +++++++++++--------------------
 1 file changed, 13 insertions(+), 23 deletions(-)
diff --git a/arch/mips/mti-sead3/sead3-pic32-i2c-drv.c b/arch/mips/mti-sead3/sead3-pic32-i2c-drv.c
index b921e5ec..80fe194 100644
--- a/arch/mips/mti-sead3/sead3-pic32-i2c-drv.c
+++ b/arch/mips/mti-sead3/sead3-pic32-i2c-drv.c
@@ -312,16 +312,13 @@ static int i2c_platform_probe(struct platform_device *pdev)
 	pr_debug("i2c_platform_probe\n");
 	r = platform_get_resource(pdev, IORESOURCE_MEM, 0);
-	if (!r) {
-		ret = -ENODEV;
-		goto out;
+	if (!r)
+		return -ENODEV;
-	priv = kzalloc(sizeof(struct i2c_platform_data), GFP_KERNEL);
-	if (!priv) {
-		ret = -ENOMEM;
-		goto out;
+	priv = devm_kzalloc(&pdev->dev, sizeof(struct i2c_platform_data),
+			    GFP_KERNEL);
+	if (!priv)
+		return -ENOMEM;
 	/* FIXME: need to allocate resource in PIC32 space */
 #if 0
@@ -330,10 +327,8 @@ static int i2c_platform_probe(struct platform_device *pdev)
 #else
 	priv->base = r->start;
 #endif
-	if (!priv->base) {
-		ret = -EBUSY;
-		goto out_mem;
+	if (!priv->base)
+		return -EBUSY;
 	priv->xfer_timeout = 200;
 	priv->ack_timeout = 200;
@@ -348,17 +343,13 @@ static int i2c_platform_probe(struct platform_device *pdev)
 	i2c_platform_setup(priv);
 	ret = i2c_add_numbered_adapter(&priv->adap);
-	if (ret == 0) {
-		platform_set_drvdata(pdev, priv);
-		return 0;
+	if (ret) {
+		i2c_platform_disable(priv);
+		return ret;
-	i2c_platform_disable(priv);
-out_mem:
-	kfree(priv);
-out:
-	return ret;
+	platform_set_drvdata(pdev, priv);
+	return 0;
 static int i2c_platform_remove(struct platform_device *pdev)
@@ -369,7 +360,6 @@ static int i2c_platform_remove(struct platform_device *pdev)
 	platform_set_drvdata(pdev, NULL);
 	i2c_del_adapter(&priv->adap);
-	kfree(priv);
 	return 0;
BtrLinux
Privacy Overview
