drivers/staging/vt6655/hostap.c | 10 ++++------
drivers/staging/vt6655/wpactl.c | 19 ++++++-------------
2 files changed, 10 insertions(+), 19 deletions(-)
diff --git a/drivers/staging/vt6655/hostap.c b/drivers/staging/vt6655/hostap.c
index f55d0fb..317c2a8 100644
--- a/drivers/staging/vt6655/hostap.c
+++ b/drivers/staging/vt6655/hostap.c
@@ -421,7 +421,6 @@ static int hostap_set_encryption(PSDevice pDevice,
unsigned char abySeq[MAX_KEY_LEN];
unsigned long long KeyRSC;
unsigned char byKeyDecMode = KEY_CTL_WEP;
- int ret = 0;
int iNodeIndex = -1;
int ii;
bool bKeyTableFull = false;
@@ -475,7 +474,7 @@ static int hostap_set_encryption(PSDevice pDevice,
MAX_KEY_LEN
- return ret;
+ return 0;
memcpy(abyKey, param->u.crypt.key, param->u.crypt.key_len);
@@ -531,7 +530,7 @@ static int hostap_set_encryption(PSDevice pDevice,
pMgmt->byCSSGK = KEY_CTL_WEP;
pMgmt->sNodeDBTable[iNodeIndex].byCipherSuite = KEY_CTL_WEP;
pMgmt->sNodeDBTable[iNodeIndex].dwKeyIndex = dwKeyIndex;
- return ret;
+ return 0;
if (param->u.crypt.seq) {
@@ -622,7 +621,7 @@ static int hostap_set_encryption(PSDevice pDevice,
pMgmt->sNodeDBTable[iNodeIndex].dwTSC47_16 = 0;
pMgmt->sNodeDBTable[iNodeIndex].wTSC15_0 = 0;
- return ret;
+ return 0;
@@ -643,7 +642,6 @@ static int hostap_get_encryption(PSDevice pDevice,
int param_len)
PSMgmtObject pMgmt = pDevice->pMgmt;
- int ret = 0;
int ii;
int iNodeIndex = 0;
@@ -663,7 +661,7 @@ static int hostap_get_encryption(PSDevice pDevice,
for (ii = 0; ii < 8; ii++)
param->u.crypt.seq[ii] = (unsigned char)pMgmt->sNodeDBTable[iNodeIndex].KeyRSC >> (ii * 8);
- return ret;
+ return 0;
diff --git a/drivers/staging/vt6655/wpactl.c b/drivers/staging/vt6655/wpactl.c
index 089e8a7..8392d4d 100644
--- a/drivers/staging/vt6655/wpactl.c
+++ b/drivers/staging/vt6655/wpactl.c
@@ -411,12 +411,11 @@ static int wpa_set_wpa(PSDevice pDevice,
struct viawget_wpa_param *param)
- int ret = 0;
pMgmt->eAuthenMode = WMAC_AUTH_OPEN;
pMgmt->bShareKeyAlgorithm = false;
- return ret;
+ return 0;
@@ -437,7 +436,6 @@ static int wpa_set_disassociate(PSDevice pDevice,
- int ret = 0;
spin_lock_irq(&pDevice->lock);
if (pDevice->bLinkPass) {
@@ -446,7 +444,7 @@ static int wpa_set_disassociate(PSDevice pDevice,
spin_unlock_irq(&pDevice->lock);
- return ret;
+ return 0;
@@ -466,14 +464,12 @@ static int wpa_set_disassociate(PSDevice pDevice,
static int wpa_set_scan(PSDevice pDevice,
- int ret = 0;
BSSvClearBSSList((void *)pDevice, pDevice->bLinkPass);
bScheduleCommand((void *)pDevice, WLAN_CMD_BSSID_SCAN, NULL);
- return ret;
+ return 0;
@@ -494,11 +490,10 @@ static int wpa_get_bssid(PSDevice pDevice,
- int ret = 0;
memcpy(param->u.wpa_associate.bssid, pMgmt->abyCurrBSSID , 6);
- return ret;
+ return 0;
@@ -520,14 +515,13 @@ static int wpa_get_ssid(PSDevice pDevice,
PWLAN_IE_SSID pItemSSID;
- int ret = 0;
pItemSSID = (PWLAN_IE_SSID)pMgmt->abyCurrSSID;
memcpy(param->u.wpa_associate.ssid, pItemSSID->abySSID , pItemSSID->len);
param->u.wpa_associate.ssid_len = pItemSSID->len;
- return ret;
+ return 0;
@@ -668,7 +662,6 @@ static int wpa_set_associate(PSDevice pDevice,
unsigned char abyNullAddr[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
unsigned char abyWPAIE[64];
- int ret = 0;
bool bWepEnabled = false;
// set key type & algorithm
@@ -788,7 +781,7 @@ static int wpa_set_associate(PSDevice pDevice,
bScheduleCommand((void *)pDevice, WLAN_CMD_SSID, NULL);
- return ret;
+ return 0;
