hwmon: (ultra45_env) Introduce managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions. Also, the unnecessary label out_free is removed.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Signed-off-by: Guenter Roeck
 drivers/hwmon/ultra45_env.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/hwmon/ultra45_env.c b/drivers/hwmon/ultra45_env.c
index fb3e693..7d46586 100644
--- a/drivers/hwmon/ultra45_env.c
+++ b/drivers/hwmon/ultra45_env.c
@@ -252,7 +252,7 @@ static const struct attribute_group env_group = {
 static int env_probe(struct platform_device *op)
-	struct env *p = kzalloc(sizeof(*p), GFP_KERNEL);
+	struct env *p = devm_kzalloc(&op->dev, sizeof(*p), GFP_KERNEL);
 	int err = -ENOMEM;
 	if (!p)
@@ -262,7 +262,7 @@ static int env_probe(struct platform_device *op)
 	p->regs = of_ioremap(&op->resource[0], 0, REG_SIZE, "pic16f747");
 	if (!p->regs)
-		goto out_free;
+		goto out;
 	err = sysfs_create_group(&op->dev.kobj, &env_group);
 	if (err)
@@ -286,8 +286,6 @@ out_sysfs_remove_group:
 out_iounmap:
 	of_iounmap(&op->resource[0], p->regs, REG_SIZE);
-out_free:
-	kfree(p);
 	goto out;
@@ -299,7 +297,6 @@ static int env_remove(struct platform_device *op)
 		sysfs_remove_group(&op->dev.kobj, &env_group);
 		hwmon_device_unregister(p->hwmon_dev);
-		kfree(p);
 	return 0;
