drivers: staging: iio: accel: Removed unnecessary variable
Author: Tina Johnson <tinajohnson.1234@gmail.com>
Variable len is used only to store the return value. Hence len is
removed and the return statement modified. Coccinelle was used to
detect such removable variables:
@rule1@
identifier ret;
expression e;
-ret =
+return
           e;
-return ret;
Signed-off-by: Tina Johnson
 drivers/staging/iio/accel/sca3000_core.c | 6 ++----
 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/iio/accel/sca3000_core.c b/drivers/staging/iio/accel/sca3000_core.c
index 31fb218..b614f27 100644
--- a/drivers/staging/iio/accel/sca3000_core.c
+++ b/drivers/staging/iio/accel/sca3000_core.c
@@ -870,7 +870,7 @@ static ssize_t sca3000_query_free_fall_mode(struct device *dev,
 					    struct device_attribute *attr,
 					    char *buf)
-	int ret, len;
+	int ret;
 	struct iio_dev *indio_dev = dev_to_iio_dev(dev);
 	struct sca3000_state *st = iio_priv(indio_dev);
 	int val;
@@ -881,9 +881,7 @@ static ssize_t sca3000_query_free_fall_mode(struct device *dev,
 	mutex_unlock(&st->lock);
 	if (ret < 0)
 		return ret;
-	len = sprintf(buf, "%d\n",
-		      !!(val & SCA3000_FREE_FALL_DETECT));
-	return len;
+	return sprintf(buf, "%d\n", !!(val & SCA3000_FREE_FALL_DETECT));
BtrLinux
Privacy Overview
