Staging rtl8172: Remove unnecessary typecast
Author: Vatika Harlalka <vatikaharlalka@gmail.com>
Using addressof and then casting to the original type is unneeded.
So these casts can be removed.
Issue detected via Coccinelle script.
Signed-off-by: Vatika Harlalka
 drivers/staging/rtl8712/hal_init.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8712/hal_init.c b/drivers/staging/rtl8712/hal_init.c
index 324da34..0a1c631 100644
--- a/drivers/staging/rtl8712/hal_init.c
+++ b/drivers/staging/rtl8712/hal_init.c
@@ -92,7 +92,7 @@ static u32 rtl871x_open_fw(struct _adapter *padapter, const u8 **ppmappedfw)
 static void fill_fwpriv(struct _adapter *padapter, struct fw_priv *pfwpriv)
-	struct dvobj_priv *pdvobj = (struct dvobj_priv *)&padapter->dvobjpriv;
+	struct dvobj_priv *pdvobj = &padapter->dvobjpriv;
 	struct registry_priv *pregpriv = &padapter->registrypriv;
 	memset(pfwpriv, 0, sizeof(struct fw_priv));
