drivers: staging: iio: meter: Removed unnecessary variable
Author: Tina Johnson <tinajohnson.1234@gmail.com>
Variable len is used only to store the return value. Hence len is
removed and the return statement modified. Coccinelle was used to
detect such removable variables:
@rule1@
identifier ret;
expression e;
-ret =
+return
e;
-return ret;
Signed-off-by: Tina Johnson
drivers/staging/iio/meter/ade7758_core.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/iio/meter/ade7758_core.c b/drivers/staging/iio/meter/ade7758_core.c
index 7e287da..652aa10 100644
--- a/drivers/staging/iio/meter/ade7758_core.c
+++ b/drivers/staging/iio/meter/ade7758_core.c
@@ -485,7 +485,7 @@ static ssize_t ade7758_read_frequency(struct device *dev,
struct device_attribute *attr,
char *buf)
- int ret, len = 0;
+ int ret;
u8 t;
int sps;
@@ -498,8 +498,7 @@ static ssize_t ade7758_read_frequency(struct device *dev,
t = (t >> 5) & 0x3;
sps = 26040 / (1 << t);
- len = sprintf(buf, "%d SPS\n", sps);
- return len;
+ return sprintf(buf, "%d SPS\n", sps);
static ssize_t ade7758_write_frequency(struct device *dev, |
char *buf)
- int ret, len = 0;
+ int ret;
u8 t;
int sps;
t = (t >> 5) & 0x3;
- return len;
