dmaengine: fix platform_no_drv_owner.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
drivers/dma/xgene-dma.c:2079:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
CC: Rameshwar Prasad Sahu
Signed-off-by: Fengguang Wu
Signed-off-by: Vinod Koul
 drivers/dma/xgene-dma.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/dma/xgene-dma.c b/drivers/dma/xgene-dma.c
index 8a36946..f52e3750 100755
--- a/drivers/dma/xgene-dma.c
+++ b/drivers/dma/xgene-dma.c
@@ -2076,7 +2076,6 @@ static struct platform_driver xgene_dma_driver = {
 	.remove = xgene_dma_remove,
 	.driver = {
 		.name = "X-Gene-DMA",
-		.owner = THIS_MODULE,
 		.of_match_table = xgene_dma_of_match_ptr,
BtrLinux
Privacy Overview
