ASoC: Intel: fix array_size.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
sound/soc/intel/haswell/sst-haswell-ipc.c:646:28-29: WARNING: Use ARRAY_SIZE
 Use ARRAY_SIZE instead of dividing sizeof array with sizeof an element
Semantic patch information:
 This makes an effort to find cases where ARRAY_SIZE can be used such as
 where there is a division of sizeof the array by the sizeof its first
 element or by any indexed element or the element type. It replaces the
 division of the two sizeofs by ARRAY_SIZE.
Generated by: scripts/coccinelle/misc/array_size.cocci
CC: Jie Yang
Signed-off-by: Fengguang Wu
Signed-off-by: Mark Brown
 sound/soc/intel/haswell/sst-haswell-ipc.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/sound/soc/intel/haswell/sst-haswell-ipc.c b/sound/soc/intel/haswell/sst-haswell-ipc.c
index d75f09e..344a1e9 100644
--- a/sound/soc/intel/haswell/sst-haswell-ipc.c
+++ b/sound/soc/intel/haswell/sst-haswell-ipc.c
@@ -466,7 +466,7 @@ static void hsw_fw_ready(struct sst_hsw *hsw, u32 header)
 		/* log the FW version info got from the mailbox here. */
 		memcpy(fw_info, fw_ready.fw_info, fw_ready.fw_info_size);
 		pinfo = &fw_info[0];
-		for (i = 0; i < sizeof(tmp) / sizeof(char *); i++)
+		for (i = 0; i < ARRAY_SIZE(tmp); i++)
 			tmp[i] = strsep(&pinfo, " ");
 		dev_info(hsw->dev, "FW loaded, mailbox readback FW info: type %s, - "
 			"version: %s.%s, build %s, source commit id: %s\n",
