ata: remove deprecated use of pci api
Author: Quentin Lambert <lambert.quentin@gmail.com>
Replace occurences of the pci api by appropriate call to the dma api.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr)
@deprecated@
idexpression id;
position p;
  pci_dma_supported@p ( id, ...)
  pci_alloc_consistent@p ( id, ...)
@bad1@
idexpression id;
position deprecated.p;
...when != &id->dev
   when != pci_get_drvdata ( id )
   when != pci_enable_device ( id )
@depends on !bad1@
idexpression id;
expression direction;
- pci_dma_supported@p ( id,
+ dma_supported ( &id->dev,
+ , GFP_ATOMIC
- pci_alloc_consistent@p ( id,
+ dma_alloc_coherent ( &id->dev,
+ , GFP_ATOMIC
Signed-off-by: Quentin Lambert
Signed-off-by: Tejun Heo
 drivers/ata/acard-ahci.c    | 10 +++++-----
 drivers/ata/ahci.c          | 10 +++++-----
 drivers/ata/libata-sff.c    |  4 ++--
 drivers/ata/pata_atp867x.c  |  4 ++--
 drivers/ata/pata_cs5520.c   |  4 ++--
 drivers/ata/pata_hpt3x3.c   |  4 ++--
 drivers/ata/pata_ninja32.c  |  4 ++--
 drivers/ata/pata_pdc2027x.c |  4 ++--
 drivers/ata/pata_scc.c      |  4 ++--
 drivers/ata/pata_sil680.c   |  4 ++--
 drivers/ata/pdc_adma.c      |  4 ++--
 drivers/ata/sata_inic162x.c |  4 ++--
 drivers/ata/sata_mv.c       | 10 +++++-----
 drivers/ata/sata_nv.c       | 12 ++++++------
 drivers/ata/sata_promise.c  |  4 ++--
 drivers/ata/sata_qstor.c    | 10 +++++-----
 drivers/ata/sata_sil.c      |  4 ++--
 drivers/ata/sata_sil24.c    | 10 +++++-----
 drivers/ata/sata_svw.c      |  4 ++--
 drivers/ata/sata_sx4.c      |  4 ++--
 drivers/ata/sata_via.c      |  4 ++--
 drivers/ata/sata_vsc.c      |  4 ++--
 22 files changed, 63 insertions(+), 63 deletions(-)
diff --git a/drivers/ata/acard-ahci.c b/drivers/ata/acard-ahci.c
index c962886..12489ce 100644
--- a/drivers/ata/acard-ahci.c
+++ b/drivers/ata/acard-ahci.c
@@ -181,10 +181,10 @@ static int acard_ahci_configure_dma_masks(struct pci_dev *pdev, int using_dac)
 	int rc;
 	if (using_dac &&
-	    !pci_set_dma_mask(pdev, DMA_BIT_MASK(64))) {
-		rc = pci_set_consistent_dma_mask(pdev, DMA_BIT_MASK(64));
+	    !dma_set_mask(&pdev->dev, DMA_BIT_MASK(64))) {
+		rc = dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(64));
 		if (rc) {
-			rc = pci_set_consistent_dma_mask(pdev, DMA_BIT_MASK(32));
+			rc = dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(32));
 			if (rc) {
 				dev_err(&pdev->dev,
 					   "64-bit DMA enable failed\n");
@@ -192,12 +192,12 @@ static int acard_ahci_configure_dma_masks(struct pci_dev *pdev, int using_dac)
 	} else {
-		rc = pci_set_dma_mask(pdev, DMA_BIT_MASK(32));
+		rc = dma_set_mask(&pdev->dev, DMA_BIT_MASK(32));
 		if (rc) {
 			dev_err(&pdev->dev, "32-bit DMA enable failed\n");
 			return rc;
 		if (rc) {
 			dev_err(&pdev->dev,
 				"32-bit consistent DMA enable failed\n");
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c
index 33bb06e..c7a92a7 100644
--- a/drivers/ata/ahci.c
+++ b/drivers/ata/ahci.c
@@ -738,10 +738,10 @@ static int ahci_configure_dma_masks(struct pci_dev *pdev, int using_dac)
 		return 0;
 	if (using_dac &&
 		if (rc) {
 			if (rc) {
 				dev_err(&pdev->dev,
@@ -749,12 +749,12 @@ static int ahci_configure_dma_masks(struct pci_dev *pdev, int using_dac)
 	} else {
 		if (rc) {
 			return rc;
 		if (rc) {
 			dev_err(&pdev->dev,
diff --git a/drivers/ata/libata-sff.c b/drivers/ata/libata-sff.c
index 2e86e3b..cdf6215 100644
--- a/drivers/ata/libata-sff.c
+++ b/drivers/ata/libata-sff.c
@@ -3220,11 +3220,11 @@ void ata_pci_bmdma_init(struct ata_host *host)
 	 * ->sff_irq_clear method.  Try to initialize bmdma_addr
 	 * regardless of dma masks.
-	rc = pci_set_dma_mask(pdev, ATA_DMA_MASK);
+	rc = dma_set_mask(&pdev->dev, ATA_DMA_MASK);
 	if (rc)
 		ata_bmdma_nodma(host, "failed to set dma mask");
 	if (!rc) {
-		rc = pci_set_consistent_dma_mask(pdev, ATA_DMA_MASK);
+		rc = dma_set_coherent_mask(&pdev->dev, ATA_DMA_MASK);
 		if (rc)
 					"failed to set consistent dma mask");
diff --git a/drivers/ata/pata_atp867x.c b/drivers/ata/pata_atp867x.c
index a705cfc..3ea50dc 100644
--- a/drivers/ata/pata_atp867x.c
+++ b/drivers/ata/pata_atp867x.c
@@ -475,11 +475,11 @@ static int atp867x_ata_pci_sff_init_host(struct ata_host *host)
 	atp867x_fixup(host);
 	if (rc)
 		return rc;
 	return rc;
diff --git a/drivers/ata/pata_cs5520.c b/drivers/ata/pata_cs5520.c
index d65cb9d..4cb2407 100644
--- a/drivers/ata/pata_cs5520.c
+++ b/drivers/ata/pata_cs5520.c
@@ -164,11 +164,11 @@ static int cs5520_init_one(struct pci_dev *pdev, const struct pci_device_id *id)
 		return -ENODEV;
-	if (pci_set_dma_mask(pdev, DMA_BIT_MASK(32))) {
+	if (dma_set_mask(&pdev->dev, DMA_BIT_MASK(32))) {
 		printk(KERN_ERR DRV_NAME ": unable to configure DMA mask.\n");
 		return -ENODEV;
-	if (pci_set_consistent_dma_mask(pdev, DMA_BIT_MASK(32))) {
+	if (dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(32))) {
 		printk(KERN_ERR DRV_NAME ": unable to configure consistent DMA mask.\n");
 		return -ENODEV;
diff --git a/drivers/ata/pata_hpt3x3.c b/drivers/ata/pata_hpt3x3.c
index d019cdd..b2fc023 100644
--- a/drivers/ata/pata_hpt3x3.c
+++ b/drivers/ata/pata_hpt3x3.c
@@ -221,10 +221,10 @@ static int hpt3x3_init_one(struct pci_dev *pdev, const struct pci_device_id *id)
 	if (rc)
 		return rc;
 	host->iomap = pcim_iomap_table(pdev);
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/pata_ninja32.c b/drivers/ata/pata_ninja32.c
index efb272d..633aa29 100644
--- a/drivers/ata/pata_ninja32.c
+++ b/drivers/ata/pata_ninja32.c
@@ -122,10 +122,10 @@ static int ninja32_init_one(struct pci_dev *dev, const struct pci_device_id *id)
 		return rc;
 	host->iomap = pcim_iomap_table(dev);
-	rc = pci_set_dma_mask(dev, ATA_DMA_MASK);
+	rc = dma_set_mask(&dev->dev, ATA_DMA_MASK);
 	if (rc)
 		return rc;
-	rc = pci_set_consistent_dma_mask(dev, ATA_DMA_MASK);
+	rc = dma_set_coherent_mask(&dev->dev, ATA_DMA_MASK);
 	if (rc)
 		return rc;
 	pci_set_master(dev);
diff --git a/drivers/ata/pata_pdc2027x.c b/drivers/ata/pata_pdc2027x.c
index dca8251..d9ef9e2 100644
--- a/drivers/ata/pata_pdc2027x.c
+++ b/drivers/ata/pata_pdc2027x.c
@@ -730,11 +730,11 @@ static int pdc2027x_init_one(struct pci_dev *pdev,
 		return rc;
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/pata_scc.c b/drivers/ata/pata_scc.c
index 7f4cb76..5cd60d6 100644
--- a/drivers/ata/pata_scc.c
+++ b/drivers/ata/pata_scc.c
@@ -1029,10 +1029,10 @@ static int scc_host_init(struct ata_host *host)
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/pata_sil680.c b/drivers/ata/pata_sil680.c
index f597edc..c14071b 100644
--- a/drivers/ata/pata_sil680.c
+++ b/drivers/ata/pata_sil680.c
@@ -374,10 +374,10 @@ static int sil680_init_one(struct pci_dev *pdev, const struct pci_device_id *id)
 	/* Setup DMA masks */
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
 	pci_set_master(pdev);
diff --git a/drivers/ata/pdc_adma.c b/drivers/ata/pdc_adma.c
index f10631b..64d682c 100644
--- a/drivers/ata/pdc_adma.c
+++ b/drivers/ata/pdc_adma.c
@@ -593,12 +593,12 @@ static int adma_set_dma_masks(struct pci_dev *pdev, void __iomem *mmio_base)
 	int rc;
 	if (rc) {
 		return rc;
 	if (rc) {
 		dev_err(&pdev->dev, "32-bit consistent DMA enable failed\n");
 		return rc;
diff --git a/drivers/ata/sata_inic162x.c b/drivers/ata/sata_inic162x.c
index 0698278..e81a821 100644
--- a/drivers/ata/sata_inic162x.c
+++ b/drivers/ata/sata_inic162x.c
@@ -856,13 +856,13 @@ static int inic_init_one(struct pci_dev *pdev, const struct pci_device_id *ent)
 	/* Set dma_mask.  This devices doesn't support 64bit addressing. */
 	if (rc) {
 		return rc;
 	if (rc) {
 		return rc;
diff --git a/drivers/ata/sata_mv.c b/drivers/ata/sata_mv.c
index 0281785..bd74ee5 100644
--- a/drivers/ata/sata_mv.c
+++ b/drivers/ata/sata_mv.c
@@ -4320,10 +4320,10 @@ static int pci_go_64(struct pci_dev *pdev)
 	int rc;
-	if (!pci_set_dma_mask(pdev, DMA_BIT_MASK(64))) {
+	if (!dma_set_mask(&pdev->dev, DMA_BIT_MASK(64))) {
 		if (rc) {
 			if (rc) {
 				dev_err(&pdev->dev,
@@ -4331,12 +4331,12 @@ static int pci_go_64(struct pci_dev *pdev)
 	} else {
 		if (rc) {
 			return rc;
 		if (rc) {
 			dev_err(&pdev->dev,
diff --git a/drivers/ata/sata_nv.c b/drivers/ata/sata_nv.c
index 1db6f5c..7ece85f 100644
--- a/drivers/ata/sata_nv.c
+++ b/drivers/ata/sata_nv.c
@@ -756,10 +756,10 @@ static int nv_adma_slave_config(struct scsi_device *sdev)
 			blk_queue_bounce_limit(sdev1->request_queue,
 					       ATA_DMA_MASK);
-		pci_set_dma_mask(pdev, ATA_DMA_MASK);
+		dma_set_mask(&pdev->dev, ATA_DMA_MASK);
 	} else {
 		/** This shouldn't fail as it was set to this value before */
-		pci_set_dma_mask(pdev, pp->adma_dma_mask);
+		dma_set_mask(&pdev->dev, pp->adma_dma_mask);
 		if (sdev0)
 			blk_queue_bounce_limit(sdev0->request_queue,
 					       pp->adma_dma_mask);
@@ -1133,10 +1133,10 @@ static int nv_adma_port_start(struct ata_port *ap)
 	/* Ensure DMA mask is set to 32-bit before allocating legacy PRD and
 	   pad buffers */
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
@@ -1161,8 +1161,8 @@ static int nv_adma_port_start(struct ata_port *ap)
 	   These are allowed to fail since we store the value that ends up
 	   being used to set as the bounce limit in slave_config later if
 	   needed. */
-	pci_set_dma_mask(pdev, DMA_BIT_MASK(64));
-	pci_set_consistent_dma_mask(pdev, DMA_BIT_MASK(64));
+	dma_set_mask(&pdev->dev, DMA_BIT_MASK(64));
+	dma_set_coherent_mask(&pdev->dev, DMA_BIT_MASK(64));
 	pp->adma_dma_mask = *dev->dma_mask;
 	mem = dmam_alloc_coherent(dev, NV_ADMA_PORT_PRIV_DMA_SZ,
diff --git a/drivers/ata/sata_promise.c b/drivers/ata/sata_promise.c
index 3638887..0fa211e 100644
--- a/drivers/ata/sata_promise.c
+++ b/drivers/ata/sata_promise.c
@@ -1246,10 +1246,10 @@ static int pdc_ata_init_one(struct pci_dev *pdev,
 	/* initialize adapter */
 	pdc_host_init(host);
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/sata_qstor.c b/drivers/ata/sata_qstor.c
index 9a6bd4c..af987a4 100644
--- a/drivers/ata/sata_qstor.c
+++ b/drivers/ata/sata_qstor.c
@@ -557,10 +557,10 @@ static int qs_set_dma_masks(struct pci_dev *pdev, void __iomem *mmio_base)
 	int rc, have_64bit_bus = (bus_info & QS_HPHY_64BIT);
 	if (have_64bit_bus &&
 		if (rc) {
 			if (rc) {
 				dev_err(&pdev->dev,
@@ -568,12 +568,12 @@ static int qs_set_dma_masks(struct pci_dev *pdev, void __iomem *mmio_base)
 	} else {
 		if (rc) {
 			return rc;
 		if (rc) {
 			dev_err(&pdev->dev,
diff --git a/drivers/ata/sata_sil.c b/drivers/ata/sata_sil.c
index 40b76b2..dea6edc 100644
--- a/drivers/ata/sata_sil.c
+++ b/drivers/ata/sata_sil.c
@@ -770,10 +770,10 @@ static int sil_init_one(struct pci_dev *pdev, const struct pci_device_id *ent)
 		return rc;
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/sata_sil24.c b/drivers/ata/sata_sil24.c
index 5242897..4b1995e 100644
--- a/drivers/ata/sata_sil24.c
+++ b/drivers/ata/sata_sil24.c
@@ -1312,10 +1312,10 @@ static int sil24_init_one(struct pci_dev *pdev, const struct pci_device_id *ent)
 	host->iomap = iomap;
 	/* configure and activate the device */
 		if (rc) {
 			if (rc) {
 				dev_err(&pdev->dev,
@@ -1323,12 +1323,12 @@ static int sil24_init_one(struct pci_dev *pdev, const struct pci_device_id *ent)
 	} else {
 		if (rc) {
 			return rc;
 		if (rc) {
 			dev_err(&pdev->dev,
diff --git a/drivers/ata/sata_svw.c b/drivers/ata/sata_svw.c
index c630fa8..ff8307b 100644
--- a/drivers/ata/sata_svw.c
+++ b/drivers/ata/sata_svw.c
@@ -496,10 +496,10 @@ static int k2_sata_init_one(struct pci_dev *pdev, const struct pci_device_id *en
 		ata_port_pbar_desc(ap, 5, offset, "port");
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/sata_sx4.c b/drivers/ata/sata_sx4.c
index 39b5de6..3a18a8a 100644
--- a/drivers/ata/sata_sx4.c
+++ b/drivers/ata/sata_sx4.c
@@ -1476,10 +1476,10 @@ static int pdc_sata_init_one(struct pci_dev *pdev,
 	/* configure and activate */
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/sata_via.c b/drivers/ata/sata_via.c
index 47bf894..17d31fc 100644
--- a/drivers/ata/sata_via.c
+++ b/drivers/ata/sata_via.c
@@ -502,10 +502,10 @@ static int vt6421_prepare_host(struct pci_dev *pdev, struct ata_host **r_host)
 	for (i = 0; i < host->n_ports; i++)
 		vt6421_init_addrs(host->ports[i]);
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
diff --git a/drivers/ata/sata_vsc.c b/drivers/ata/sata_vsc.c
index 29e847a..183eb52 100644
--- a/drivers/ata/sata_vsc.c
+++ b/drivers/ata/sata_vsc.c
@@ -387,10 +387,10 @@ static int vsc_sata_init_one(struct pci_dev *pdev,
 	 * Use 32 bit DMA mask, because 64 bit address support is poor.
 	if (rc)
 		return rc;
 	if (rc)
 		return rc;
