NFC: pn533: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Samuel Ortiz
drivers/nfc/pn533.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/nfc/pn533.c b/drivers/nfc/pn533.c
index d46a700a..732e607 100644
--- a/drivers/nfc/pn533.c
+++ b/drivers/nfc/pn533.c
@@ -2554,8 +2554,10 @@ static int pn533_data_exchange_complete(struct pn533 *dev, void *_arg,
skb = pn533_build_response(dev);
- if (!skb)
+ if (!skb) {
+ rc = -ENOMEM;
goto error;
arg->cb(arg->cb_context, skb, 0);
kfree(arg); |
- if (!skb)
+ if (!skb) {
+ rc = -ENOMEM;
goto error;
kfree(arg);
