cw1200: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
when strict
return
- ret
+ C
Signed-off-by: Peter Senna Tschudin
Signed-off-by: John W. Linville
drivers/net/wireless/cw1200/sta.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/wireless/cw1200/sta.c b/drivers/net/wireless/cw1200/sta.c
index cd0cad7..5b84664 100644
--- a/drivers/net/wireless/cw1200/sta.c
+++ b/drivers/net/wireless/cw1200/sta.c
@@ -2289,7 +2289,6 @@ static int cw1200_upload_null(struct cw1200_common *priv)
static int cw1200_upload_qosnull(struct cw1200_common *priv)
- int ret = 0;
/* TODO: This needs to be implemented
struct wsm_template_frame frame = {
@@ -2306,7 +2305,7 @@ static int cw1200_upload_qosnull(struct cw1200_common *priv)
dev_kfree_skb(frame.skb);
- return ret;
+ return 0;
static int cw1200_enable_beaconing(struct cw1200_common *priv, |
- int ret = 0;
- return ret;
+ return 0;
