via-ircc: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
    when strict
return
- ret
+ C
Signed-off-by: Peter Senna Tschudin
Signed-off-by: David S. Miller
 drivers/net/irda/via-ircc.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/net/irda/via-ircc.c b/drivers/net/irda/via-ircc.c
index 2900af0..998bb89 100644
--- a/drivers/net/irda/via-ircc.c
+++ b/drivers/net/irda/via-ircc.c
@@ -510,10 +510,8 @@ static void via_hw_init(struct via_ircc_cb *self)
 static int via_ircc_read_dongle_id(int iobase)
-	int dongle_id = 9;	/* Default to IBM */
 	IRDA_ERROR("via-ircc: dongle probing not supported, please specify dongle_id module parameter.\n");
-	return dongle_id;
+	return 9;	/* Default to IBM */
@@ -926,7 +924,6 @@ static int via_ircc_dma_xmit(struct via_ircc_cb *self, u16 iobase)
 static int via_ircc_dma_xmit_complete(struct via_ircc_cb *self)
 	int iobase;
-	int ret = TRUE;
 	u8 Tx_status;
 	IRDA_DEBUG(3, "%s()\n", __func__);
@@ -983,7 +980,7 @@ F01_E*/
 	// Tell the network layer, that we can accept more frames
 	netif_wake_queue(self->netdev);
 //F01   }
-	return ret;
+	return TRUE;
