drivers/net/ethernet/neterion/vxge/vxge-config.c | 22 +++++++---------------
1 file changed, 7 insertions(+), 15 deletions(-)
diff --git a/drivers/net/ethernet/neterion/vxge/vxge-config.c b/drivers/net/ethernet/neterion/vxge/vxge-config.c
index 089b713..2bbd01f 100644
--- a/drivers/net/ethernet/neterion/vxge/vxge-config.c
+++ b/drivers/net/ethernet/neterion/vxge/vxge-config.c
@@ -120,7 +120,6 @@ __vxge_hw_device_register_poll(void __iomem *reg, u64 mask, u32 max_millis)
u64 val64;
u32 i = 0;
- enum vxge_hw_status ret = VXGE_HW_FAIL;
udelay(10);
@@ -139,7 +138,7 @@ __vxge_hw_device_register_poll(void __iomem *reg, u64 mask, u32 max_millis)
mdelay(1);
} while (++i <= max_millis);
- return ret;
+ return VXGE_HW_FAIL;
static inline enum vxge_hw_status
@@ -1682,12 +1681,10 @@ enum vxge_hw_status vxge_hw_driver_stats_get(
struct __vxge_hw_device *hldev,
struct vxge_hw_device_stats_sw_info *sw_stats)
- enum vxge_hw_status status = VXGE_HW_OK;
memcpy(sw_stats, &hldev->stats.sw_dev_info_stats,
sizeof(struct vxge_hw_device_stats_sw_info));
- return status;
+ return VXGE_HW_OK;
@@ -3228,7 +3225,6 @@ enum vxge_hw_status
vxge_hw_vpath_strip_fcs_check(struct __vxge_hw_device *hldev, u64 vpath_mask)
struct vxge_hw_vpmgmt_reg __iomem *vpmgmt_reg;
int i = 0, j = 0;
for (i = 0; i < VXGE_HW_MAX_VIRTUAL_PATHS; i++) {
@@ -3241,7 +3237,7 @@ vxge_hw_vpath_strip_fcs_check(struct __vxge_hw_device *hldev, u64 vpath_mask)
- return status;
* vxge_hw_mgmt_reg_Write - Write Titan register.
@@ -3979,7 +3975,6 @@ __vxge_hw_vpath_mgmt_read(
u32 i, mtu = 0, max_pyld = 0;
u64 val64;
for (i = 0; i < VXGE_HW_MAC_MAX_MAC_PORT_ID; i++) {
@@ -4009,7 +4004,7 @@ __vxge_hw_vpath_mgmt_read(
else
VXGE_HW_DEVICE_LINK_STATE_SET(vpath->hldev, VXGE_HW_LINK_DOWN);
- return status;
@@ -4039,14 +4034,13 @@ static enum vxge_hw_status
__vxge_hw_vpath_reset(struct __vxge_hw_device *hldev, u32 vp_id)
u64 val64;
val64 = VXGE_HW_CMN_RSTHDLR_CFG0_SW_RESET_VPATH(1 << (16 - vp_id));
__vxge_hw_pio_mem_write32_upper((u32)vxge_bVALn(val64, 0, 32),
&hldev->common_reg->cmn_rsthdlr_cfg0);
- return status;
@@ -4227,7 +4221,6 @@ static enum vxge_hw_status
__vxge_hw_vpath_mac_configure(struct __vxge_hw_device *hldev, u32 vp_id)
u64 val64;
struct __vxge_hw_virtualpath *vpath;
struct vxge_hw_vp_config *vp_config;
struct vxge_hw_vpath_reg __iomem *vp_reg;
@@ -4283,7 +4276,7 @@ __vxge_hw_vpath_mac_configure(struct __vxge_hw_device *hldev, u32 vp_id)
writeq(val64, &vp_reg->rxmac_vcfg1);
- return status;
@@ -4295,7 +4288,6 @@ static enum vxge_hw_status
__vxge_hw_vpath_tim_configure(struct __vxge_hw_device *hldev, u32 vp_id)
u64 val64;
struct vxge_hw_vp_config *config;
@@ -4545,7 +4537,7 @@ __vxge_hw_vpath_tim_configure(struct __vxge_hw_device *hldev, u32 vp_id)
val64 |= VXGE_HW_TIM_WRKLD_CLC_CNT_RX_TX(3);
writeq(val64, &vp_reg->tim_wrkld_clc);
- return status;
