atmel_cs: Remove typedef local_info_t
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
local_info_t. Also, the name of the struct is changed to drop the _t,
to make the name look less typedef-like.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: John W. Linville
drivers/net/wireless/atmel_cs.c | 22 +++++++++++-----------
1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/drivers/net/wireless/atmel_cs.c b/drivers/net/wireless/atmel_cs.c
index 4cfb4d9..7afc9c5 100644
--- a/drivers/net/wireless/atmel_cs.c
+++ b/drivers/net/wireless/atmel_cs.c
@@ -66,18 +66,18 @@ static void atmel_release(struct pcmcia_device *link);
static void atmel_detach(struct pcmcia_device *p_dev);
-typedef struct local_info_t {
+struct local_info {
struct net_device *eth_dev;
-} local_info_t;
static int atmel_probe(struct pcmcia_device *p_dev)
- local_info_t *local;
+ struct local_info *local;
dev_dbg(&p_dev->dev, "atmel_attach()\n");
/* Allocate space for private device-specific data */
- local = kzalloc(sizeof(local_info_t), GFP_KERNEL);
+ local = kzalloc(sizeof(*local), GFP_KERNEL);
if (!local)
return -ENOMEM;
@@ -117,7 +117,7 @@ static int atmel_config_check(struct pcmcia_device *p_dev, void *priv_data)
static int atmel_config(struct pcmcia_device *link)
- local_info_t *dev;
+ struct local_info *dev;
int ret;
const struct pcmcia_device_id *did;
@@ -141,14 +141,14 @@ static int atmel_config(struct pcmcia_device *link)
if (ret)
goto failed;
- ((local_info_t*)link->priv)->eth_dev =
+ ((struct local_info *)link->priv)->eth_dev =
init_atmel_card(link->irq,
link->resource[0]->start,
did ? did->driver_info : ATMEL_FW_TYPE_NONE,
&link->dev,
card_present,
link);
- if (!((local_info_t*)link->priv)->eth_dev)
+ if (!((struct local_info *)link->priv)->eth_dev)
goto failed;
@@ -161,20 +161,20 @@ static int atmel_config(struct pcmcia_device *link)
- struct net_device *dev = ((local_info_t*)link->priv)->eth_dev;
+ struct net_device *dev = ((struct local_info *)link->priv)->eth_dev;
dev_dbg(&link->dev, "atmel_release\n");
if (dev)
stop_atmel_card(dev);
- ((local_info_t*)link->priv)->eth_dev = NULL;
+ ((struct local_info *)link->priv)->eth_dev = NULL;
pcmcia_disable_device(link);
static int atmel_suspend(struct pcmcia_device *link)
- local_info_t *local = link->priv;
+ struct local_info *local = link->priv;
netif_device_detach(local->eth_dev);
@@ -183,7 +183,7 @@ static int atmel_suspend(struct pcmcia_device *link)
static int atmel_resume(struct pcmcia_device *link)
atmel_open(local->eth_dev);
netif_device_attach(local->eth_dev); |
-} local_info_t;
if (!local)
return -ENOMEM;
int ret;
if (ret)
goto failed;
&link->dev,
card_present,
link);
goto failed;
if (dev)
