Bluetooth: Remove typedef bluecard_info_t
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
bluecard_info_t. Also, the name of the struct is changed to drop the _t,
to make the name look less typedef-like.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
 struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Marcel Holtmann
 drivers/bluetooth/bluecard_cs.c | 35 ++++++++++++++++++-----------------
 1 file changed, 18 insertions(+), 17 deletions(-)
diff --git a/drivers/bluetooth/bluecard_cs.c b/drivers/bluetooth/bluecard_cs.c
index dfa5043..35e63aa 100644
--- a/drivers/bluetooth/bluecard_cs.c
+++ b/drivers/bluetooth/bluecard_cs.c
@@ -61,7 +61,7 @@ MODULE_LICENSE("GPL");
 /* ======================== Local structures ======================== */
-typedef struct bluecard_info_t {
+struct bluecard_info {
 	struct pcmcia_device *p_dev;
 	struct hci_dev *hdev;
@@ -78,7 +78,7 @@ typedef struct bluecard_info_t {
 	unsigned char ctrl_reg;
 	unsigned long hw_state;		/* Status of the hardware and LED control */
-} bluecard_info_t;
 static int bluecard_config(struct pcmcia_device *link);
@@ -157,7 +157,7 @@ static void bluecard_detach(struct pcmcia_device *p_dev);
 static void bluecard_activity_led_timeout(u_long arg)
-	bluecard_info_t *info = (bluecard_info_t *)arg;
+	struct bluecard_info *info = (struct bluecard_info *)arg;
 	unsigned int iobase = info->p_dev->resource[0]->start;
 	if (!test_bit(CARD_HAS_PCCARD_ID, &(info->hw_state)))
@@ -173,7 +173,7 @@ static void bluecard_activity_led_timeout(u_long arg)
-static void bluecard_enable_activity_led(bluecard_info_t *info)
+static void bluecard_enable_activity_led(struct bluecard_info *info)
@@ -215,7 +215,7 @@ static int bluecard_write(unsigned int iobase, unsigned int offset, __u8 *buf, i
-static void bluecard_write_wakeup(bluecard_info_t *info)
+static void bluecard_write_wakeup(struct bluecard_info *info)
 	if (!info) {
 		BT_ERR("Unknown device");
@@ -368,7 +368,8 @@ static int bluecard_read(unsigned int iobase, unsigned int offset, __u8 *buf, in
-static void bluecard_receive(bluecard_info_t *info, unsigned int offset)
+static void bluecard_receive(struct bluecard_info *info,
+			     unsigned int offset)
 	unsigned int iobase;
 	unsigned char buf[31];
@@ -497,7 +498,7 @@ static void bluecard_receive(bluecard_info_t *info, unsigned int offset)
 static irqreturn_t bluecard_interrupt(int irq, void *dev_inst)
-	bluecard_info_t *info = dev_inst;
+	struct bluecard_info *info = dev_inst;
 	unsigned char reg;
@@ -562,7 +563,7 @@ static irqreturn_t bluecard_interrupt(int irq, void *dev_inst)
 static int bluecard_hci_set_baud_rate(struct hci_dev *hdev, int baud)
-	bluecard_info_t *info = hci_get_drvdata(hdev);
+	struct bluecard_info *info = hci_get_drvdata(hdev);
 	struct sk_buff *skb;
 	/* Ericsson baud rate command */
@@ -611,7 +612,7 @@ static int bluecard_hci_set_baud_rate(struct hci_dev *hdev, int baud)
 static int bluecard_hci_flush(struct hci_dev *hdev)
 	/* Drop TX queue */
 	skb_queue_purge(&(info->txq));
@@ -622,7 +623,7 @@ static int bluecard_hci_flush(struct hci_dev *hdev)
 static int bluecard_hci_open(struct hci_dev *hdev)
 	if (test_bit(CARD_HAS_PCCARD_ID, &(info->hw_state)))
 		bluecard_hci_set_baud_rate(hdev, DEFAULT_BAUD_RATE);
@@ -643,7 +644,7 @@ static int bluecard_hci_open(struct hci_dev *hdev)
 static int bluecard_hci_close(struct hci_dev *hdev)
 	if (!test_and_clear_bit(HCI_RUNNING, &(hdev->flags)))
 		return 0;
@@ -663,7 +664,7 @@ static int bluecard_hci_close(struct hci_dev *hdev)
 static int bluecard_hci_send_frame(struct hci_dev *hdev, struct sk_buff *skb)
 	switch (bt_cb(skb)->pkt_type) {
 	case HCI_COMMAND_PKT:
@@ -691,7 +692,7 @@ static int bluecard_hci_send_frame(struct hci_dev *hdev, struct sk_buff *skb)
 /* ======================== Card services HCI interaction ======================== */
-static int bluecard_open(bluecard_info_t *info)
+static int bluecard_open(struct bluecard_info *info)
@@ -806,7 +807,7 @@ static int bluecard_open(bluecard_info_t *info)
-static int bluecard_close(bluecard_info_t *info)
+static int bluecard_close(struct bluecard_info *info)
 	struct hci_dev *hdev = info->hdev;
@@ -833,7 +834,7 @@ static int bluecard_close(bluecard_info_t *info)
 static int bluecard_probe(struct pcmcia_device *link)
-	bluecard_info_t *info;
+	struct bluecard_info *info;
 	/* Create new info device */
 	info = devm_kzalloc(&link->dev, sizeof(*info), GFP_KERNEL);
@@ -857,7 +858,7 @@ static void bluecard_detach(struct pcmcia_device *link)
-	bluecard_info_t *info = link->priv;
+	struct bluecard_info *info = link->priv;
 	int i, n;
 	link->config_index = 0x20;
@@ -897,7 +898,7 @@ failed:
 static void bluecard_release(struct pcmcia_device *link)
 	bluecard_close(info);
