Drivers: ide: Remove typedef atiixp_ide_timing
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
atiixp_ide_timing.
The following Coccinelle semantic patch detects the case:
@tn1@
type td;
typedef struct { ... } td;
@script:python tf@
td << tn1.td;
tdres;
coccinelle.tdres = td;
type tn1.td;
identifier tf.tdres;
-typedef
struct
+ tdres
-td
type tn1.td;
-td
+ struct tdres
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/ide/atiixp.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/ide/atiixp.c b/drivers/ide/atiixp.c
index dbd0f24..76650e9 100644
--- a/drivers/ide/atiixp.c
+++ b/drivers/ide/atiixp.c
@@ -19,12 +19,12 @@
#define ATIIXP_IDE_UDMA_CONTROL 0x54
#define ATIIXP_IDE_UDMA_MODE 0x56
-typedef struct {
+struct atiixp_ide_timing {
u8 command_width;
u8 recover_width;
-} atiixp_ide_timing;
-static atiixp_ide_timing pio_timing[] = {
+static struct atiixp_ide_timing pio_timing[] = {
{ 0x05, 0x0d },
{ 0x04, 0x07 },
{ 0x03, 0x04 },
@@ -32,7 +32,7 @@ static atiixp_ide_timing pio_timing[] = {
{ 0x02, 0x00 },
-static atiixp_ide_timing mdma_timing[] = {
+static struct atiixp_ide_timing mdma_timing[] = {
{ 0x07, 0x07 },
{ 0x02, 0x01 },
{ 0x02, 0x00 }, |
@@ -19,12 +19,12 @@
-typedef struct {
u8 command_width;
u8 recover_width;
{ 0x05, 0x0d },
{ 0x04, 0x07 },
{ 0x03, 0x04 },
{ 0x02, 0x00 },
{ 0x07, 0x07 },
{ 0x02, 0x01 },
{ 0x02, 0x00 },
